Create a PD+ Account
Welcome to VEX PD+! All users possessing a VEX account, including previous VEX Certification users, are entitled to a complementary set of resources within VEX Professional Development Plus. These resources will kick-start your VEX journey with free Intro Courses and access to the Professional Learning Community upon earning a certificate.
Login to VEX PD+
PD+ homepage with the Login option in the upper right corner highlighted.
Start by going to pd.vex.com and select “Login.”
Screenshot of the Login screen reading Login to an existing account, with spaces to enter your email and password, and a login button on the bottom left.
Login using your VEX Account.
Don’t have a VEX Account? Fill out this form to register for a VEX Account.
Then navigate back to pd.vex.com after creating your account, and log in.
PD+ Get Started Tour, with the Get started button in the bottom of the prompt window highlighted.
Once logged in, you will see the dashboard. Because you have not activated a license key, some features will be locked. You will also see a pop-up window offering a tour of PD+. Select 'Get Started' to start the tour.
PD+ Get Started Tour dialog with the Previous and Next button on the bottom left and right corners respectively, highlighted.
You will be provided with a high-level overview of each PD+ feature. Select 'Next' to advance to the next feature, or 'Previous' to go back to the last feature.
PD+ Get Started Tour dialog with the Finish Tour button highlighted.
When you are finished with the tour, select 'Finish Tour.'
PD+ Get Started Tour dialog with the Skip Tour option in the upper right highlighted.
If you do not wish to take the tour, select 'Skip Tour.'
PD+ Navigation menu with Masterclasses and Intro course options highlighted.
Now you will be able to access Intro Courses to earn certifications. Become a PD+ All-Access member to unlock VEX Masterclasses, comprehensive, guided lessons led by VEX experts.
PD+ course tile examples showing options for multiple platforms.
For more information about VEX Masterclasses and Intro Courses, view this article: Understanding the Pathways to VEX Certifications.
PD+ Navigation menu with the Community option highlighted.
You can view all discussions in the PD+ Community to begin learning from other educators around the world. After completing a free Intro Course and earning a certificate, you will be able to create your own posts in the discussion for the corresponding platform if you have a free PD+ Account.
By becoming a PD+ All-Access member, you will be able to participate in discussions for all VEX platforms.
For more information about the Community, view this section of articles in the VEX Library.
Activating a License Key
PD+ Quick Links navigation in the PD+ Dashboard with the Activate License option in the lower left corner highlighted.
To activate a VEX PD+ License Key, follow the steps in this article.
If you are having trouble logging in or need additional support, click here.
