The VEX AIR Flight Simulator in VEXcode AIR allows you to practice flying a VEX AIR Drone in a safe, virtual environment. This will give you time to practice flying and getting comfortable with how the VEX AIR Drone Controller moves the drone in the air, before taking off for the first time.
This article explains how to get started using the simulator, and the options within the simulator.
Accessing the Simulator
Ensure VEXcode AIR is open on your device. See this page for more information on accessing VEXcode AIR.
Select the Simulator tab in the upper left corner of the screen to open the VEX AIR Flight Simulator.
In VEXcode, the simulator will open to the practice Rings layout, showing the Pilot View.
When the simulator opens, the controller will make a sound and a dialog will appear in the center of the screen indicating that the Propeller Lock is engaged.
The controller screen will also indicate that the controller is connected to the simulator.
Note: If the controller is already connected to a physical VEX AIR Drone, you will not be able to access the simulator. You will be prompted to power off the drone in order to use the simulator.
Propeller Lock
By default, the Propeller Lock is enabled when the simulator opens. The VEX AIR Drone's Propeller Lock is an important safety feature that helps ensure safe drone operation. To learn more about the Propeller Lock on the physical drone, see this article.
The drone cannot take off when the Propeller Lock is engaged. Similar to how the Propeller Lock behaves on the physical drone, the propellers will lock anytime the simulator is reset or the layout is changed.
While the Propeller Lock is engaged, the power button on the virtual drone in the simulator will flash blue as shown in this video. The power button on the physical controller will also flash blue.
Select the power button on the virtual drone in the dialog box to disengage the Propeller Lock, as shown in this video. Then the propellers will be unlocked, and the drone will be ready to fly.
Using the Controller with the Simulator
With the Propeller Lock disabled, the drone can be flown using the same controls as a real-life flight! The simulator utilizes the same controls as the default_fly project. To learn more about all controller settings available in the VEX AIR Flight Simulator, see this article.
Flying in the Simulator
Take off using the Takeoff & Land button on the controller. Press the button to open the project menu. Then hold the button until the drone takes off from the platform.
Pressing the Takeoff & Land button while flying in the simulator will land the drone. Press the button to open the menu. Then press the button again, or touch the Land button on the controller screen, to land the drone in its current location.
The movement of the drone is controlled by the movements of the joysticks. See this article to learn more about the controls in the default_fly project.
The Emergency Stop feature also functions in the simulator. Pressing the Propeller Lock and Takeoff & Land buttons at the same time will immediately shut down the motors and cause the drone to fall to the ground, as shown in this animation. This safety feature is especially important when flying a physical drone, and learning how to use it in the simulator is part of developing safe flying habits.
Camera Options
Different camera views in the VEX AIR Flight Simulator help you see the drone from multiple perspectives. This can help you better understand your drone’s position, movement, and environment while flying. Choosing the camera view that works best for you will depend on your preferences, and the task you are trying to complete.
To change the camera view of the drone, select the Change View button on the controller.
This will rotate through the following camera options, as shown in the video above:
- Pilot View - Shows the drone from the pilot’s position outside the field, just like in a competition. This view helps build spatial awareness and practice line-of-sight flying.
Front Camera - Displays the forward-facing camera (matching the drone's forward camera) to show what the drone “sees” straight ahead. It’s useful for navigating through obstacles or lining up with targets.
- This view in the simulator displays a smaller screen space, including the icons on the controller's screen, to emulate what would be seen while using the Front Camera view during physical drone flights.
Down Camera -Displays the downward-facing camera view (matching the drone’s own downward camera.) This is useful for aligning with objects and scoring elements.
- This view in the simulator displays a smaller screen space, including the icons on the controller's screen, to emulate what would be seen while using the Down Camera view during physical drone flights.
- Chase View - Follows behind the drone as it moves. This view gives a dynamic perspective that helps visualize flight paths and direction changes.
- Split Screen 1 - Combines Chase View on the top and Front Camera on the bottom.
- Split Screen 2 - Combines Chase View on the top and Down Camera on the bottom.
Controller Configuration
Select the Info button on the lower right side of the screen to view the controller configuration.
The Controller Configuration shows the controls based on the current settings. Select the X button in the upper left corner to close the configuration and return to the field.
Features in the Flight Simulator
Simulator Layouts
There are two available practice layouts in the simulator.
The Rings Layout is designed for practicing basic drone movements. Color-coded rings help students practice specific motions, such as using the yellow rings to practice rotation (yaw).
Students can also fly through multiple rings to combine movements into more complex flight paths. Counters in the upper-left corner track the number of rings flown through and any collisions.
The Competition Layout is designed for students who are comfortable with basic drone movements. Students can practice picking up and delivering objects using modules. A counter in the upper-left corner tracks the number of objects successfully delivered.
Mini-Map
The mini-map in the lower left corner of the simulator shows the drone's path in a top-down view of the field as you fly.
A line tracing the drone's path in real-time appears on the mini-map to help keep track of the flight path.
The mini-map can be turned off in the Pre-Flight Checklist at any time.
Pre-Flight Checklist Menu
Select the Gear icon on the lower right side of the screen to open the Pre-Flight Checklist.
In the Pre-Flight Checklist, you can select your desired options for Layout, Module, Pilot Position, Drone Audio, and Mini Map . By default, the simulator will begin in the Rings Layout, with the Magnet Module, from the Side Pilot Position, with the Audio off, and the Mini Map on.
Select the Confirm button on the bottom of the window to save your selections. Selecting the X button in the top left corner will close the checklist without saving your choices.
When the Competition Layout is selected, the additional option of Field Side appears. The default is the Red side, positioning the drone on the platform closest to the red game elements.
Scoring
All layouts feature scoring to help you monitor your progress and success while flying and completing tasks on the field. Below you can see some of the options for scoring in the simulator.
In the practice Rings Layout, the counter indicates the number of rings that are flown through, and the number of times the drone collides with a ring.
In the practice Competition Layout, the counter indicates the number of rings flown through, and the number of game objects placed in or on each of the scoring locations.
Resetting
Select the Reset button in the lower right corner of the screen to reset the field and return the drone to the starting position on the platform, with the Propeller Lock enabled.
Flight School in the Simulator
In addition to the two practice layouts, additional layouts are available as part of Flight School.
Flight School gives users an opportunity to test their piloting skills through mission-based challenges directly from the VEX AIR Virtual Flight Course, real-time feedback, and shareable badges. This allows users to clearly track and share progress over time.
To open Flight School, select the Flight School button in the lower left corner of the simulator.
Propeller Lock in the Competition Layout
In the Competition layout, the Propeller Lock dialog also has an option for module selection.
Select your desired module – Magnet or Motorized. Magnet is selected by default.
Any time the drone is landed on a platform, the Propeller Lock will become available so that you can change the module.
A Prop Lock Available callout will appear at the top of the simulator screen, indicating that the Propeller Lock can be engaged.
Select the Propeller Lock button on the VEX AIR Drone Controller to engage the Propeller Lock.
The same dialog will appear indicating that the Propeller Lock is engaged, and giving the option to select a module. Select your desired module, and you can disengage Propeller Lock and continue flying with the new module.
