Using the V5RC Spin Up Playground Window
The V5RC Spin Up Playground Window is a virtual representation of the Field for the V5RC Spin Up (2022-2023) Competition game. The Virtual Skills Window is a space for Disco, the Hero Bot, to interact and move.
VEXcode VR Playground window showing block code beside the V5RC Spin Up field and virtual robot
How to Choose Your Starting Position
VEXcode VR with the Spin Up Playground open beside the block-based coding workspace
When the Playground Window opens, you will then be prompted to select a starting configuration for the robot.
See more information about selecting a starting configuration in this article.
V5RC Spin Up Playground window showing the block coding workspace and virtual field view
To reopen or change the starting configuration, select the location icon.
How to Start, Stop and Reset a project
VEXcode VR Playground window showing the V5RC Spin Up field, block workspace, and robot controls
Select the “Start” button to start a project.
This button will change to a “Stop” button when a project is actively running.
V5RC Spin Up Playground window showing the virtual field, robot, and game elements
Selecting the “Stop” button will stop the project and the timer immediately.
The Score Window will appear at this time. See below for more information on the Score Window.
VEXcode VR workspace with the V5RC Spin Up Playground window open
Select the “Reset” button to reset the timer, point value, and Field.
How to View Your Score and the Timer
V5RC Spin Up Playground window showing the virtual field, robot, and controls
Your score can be seen above the Field on the left side. This will be updated in real-time after the project is started.
VEXcode VR Playground window showing the V5RC Spin Up field, robot, and coding workspace
The timer is located above the Field on the right side.
The timer begins when a project is started and counts down from 1:00. The timer will count down until “Stop” is selected, the [Stop project] Block is used in the project, or the timer reaches 0 seconds.
How to Use Match Loads
VEXcode VR Playground window showing the code workspace and VRC Spin Up field side by side
Match Loads are available to place on the Field during a match. See this article about Using Match Loads in V5RC Virtual Skills for more information.
How to Retry and Close the Score Window
Virtual Skills Match Results screen with the score and skills stop time highlighted in the middle of the screen
The Score Window appears when the timer reaches 0, or if the project is stopped.
The Score Window shows your team's name, number, total score, and Skills Stop Time.
Note: you cannot submit scores in a previous V5RC game's Playground.
Virtual Skills Match Results screen with the retry button highlighted in the middle of the screen
Select the “Retry” button to return to the Field and reset the timer and score.
Virtual Skills Match Results screen with a X highlighted on the top left
Select the “X” in the top-left corner to close the Score Window and return to the Field.
This will not reset the Field, timer, or score. It will return to the Field exactly as it was at the moment the project was stopped.
How to Expand and Shrink the Window
VEXcode VR workspace showing block code beside the V5RC Spin Up Playground window for programming the virtual robot
The window begins at a smaller size by default. If you want to expand the window, select the “Expand” button at the top left corner.
VEXcode VR Playground window showing the Spin Up field and coding workspace for the virtual robot
Select “Shrink” in the top-left corner to return the window to the default size.
How to Hide and Show the Window
VEXcode VR Playground window showing the V5RC Spin Up field, coding workspace, and virtual robot controls
Select the “Hide” button to collapse the V5RC Virtual Skills Window. This will still keep the red toolbar at the top of the window visible.
VEXcode VR Playground window with the Spin Up field, robot dashboard, and playback controls
To view the full window again, select the “Show” button.
How to Select Different Camera Views
VEXcode VR blocks for spinning the roller and driving the V5RC Spin Up robot in the Playground window
Select the “Top Camera” button to see an overhead view of the entire Field. This is the default view when you open the V5RC Virtual Skills Window.
V5RC Spin Up Playground window showing the coding workspace and competition field view
Select the “Chase Camera” button to see a behind-the-robot view.
VEXcode VR Playground window showing the block workspace beside the V5RC Spin Up field
Select the “Orbit Camera” button to see an overview of Moby and the full Field.
How to View Settings
VEXcode VR workspace showing blocks used to program the V5RC Spin Up Playground robot
Select the gear icon to open the Settings window.
VEXcode VR Playground window showing the Spin Up field, robot, and coding workspace
Data about your device will be displayed in the Settings window. This can be used to help troubleshoot any performance issues.
