The VRC Spin Up Playground Window is a virtual representation of the Field for the VRC Spin Up (2022-2023) Competition game. The Virtual Skills Window is a space for Disco, the Hero Bot, to interact and move.
How to Choose Your Starting Position
When the Playground Window opens, you will then be prompted to select a starting configuration for the robot.
See more information about selecting a starting configuration in this article.
To reopen or change the starting configuration, select the location icon.
How to Start, Stop and Reset a project
Select the “Start” button to start a project.
This button will change to a “Stop” button when a project is actively running.
Selecting the “Stop” button will stop the project and the timer immediately.
The Score Window will appear at this time. See below for more information on the Score Window.
Select the “Reset” button to reset the timer, point value, and Field.
How to View Your Score and the Timer
Your score can be seen above the Field on the left side. This will be updated in real-time after the project is started.
The timer is located above the Field on the right side.
The timer begins when a project is started and counts down from 1:00. The timer will count down until “Stop” is selected, the [Stop project] Block is used in the project, or the timer reaches 0 seconds.
How to Use Match Loads
Match Loads are available to place on the Field during a match. See this article about Using Match Loads in VRC Virtual Skills for more information.
How to Retry and Close the Score Window
The Score Window appears when the timer reaches 0, or if the project is stopped.
The Score Window shows your team's name, number, total score, and Skills Stop Time.
Note: you cannot submit scores in a previous VRC game's Playground.
Select the “Retry” button to return to the Field and reset the timer and score.
Select the “X” in the top-left corner to close the Score Window and return to the Field.
This will not reset the Field, timer, or score. It will return to the Field exactly as it was at the moment the project was stopped.
How to Expand and Shrink the Window
The window begins at a smaller size by default. If you want to expand the window, select the “Expand” button at the top left corner.
Select “Shrink” in the top-left corner to return the window to the default size.
How to Hide and Show the Window
Select the “Hide” button to collapse the VRC Virtual Skills Window. This will still keep the red toolbar at the top of the window visible.
To view the full window again, select the “Show” button.
How to Select Different Camera Views
Select the “Top Camera” button to see an overhead view of the entire Field. This is the default view when you open the VRC Virtual Skills Window.
Select the “Chase Camera” button to see a behind-the-robot view.
Select the “Orbit Camera” button to see an overview of Moby and the full Field.
How to View Settings
Select the gear icon to open the Settings window.
Data about your device will be displayed in the Settings window. This can be used to help troubleshoot any performance issues.
