The VEX Classroom App is a useful tool that allows you to get started quickly. The app can be used to easily update 123 Robot firmware, including updating multiple robots at one time. You can also use it to rename 123 Robots, monitor robot battery life, and more!
Navigate to your device’s app store and search for VEX Classroom to download the app if you have not already done so.
Note: The VEX Classroom App is available on the following platforms:
- Apple App Store - iPads, iPhones, iPod Touches
- Google Play Store - Android phones and tablets
- Amazon Appstore - Amazon Fire tablets
Scan for Devices
Open the VEX Classroom App and select Scan for VEX Devices to begin.
Updating Firmware
The firmware on one or multiple 123 Robots can be updated at a time using the VEX Classroom App. 123 Robots that need firmware updates will show up as orange in the VEX Devices list.
Select Update All to update the firmware of all detected 123 Robots.
For more information on how to update one or multiple 123 Robots using the VEX Classroom App, view the Update the 123 Robot Using the VEX Classroom App article.
Renaming a 123 Robot
To rename a 123 Robot, select the 123 Robot you want to rename from the VEX Devices list.
Select Rename.
Select the text field to begin typing in the new name. Names are limited to 7 characters and can include letters A–Z, numbers, spaces, underscores, and hyphens.
Select Save Name to set the 123 Robot's name.
The new name will then be displayed.
Locating a 123 Robot
A 123 Robot can be located using the app. The location feature identifies a specific 123 Robot by making the indicator light on the 123 Robot flash yellow, and playing a chirping sound.
To locate a 123 Robot, select the 123 Robot that is to be located from the VEX Devices list.
Select Locate.
The indicator light on the 123 Robot will flash yellow, and the 123 Robot will make a ‘chirp’ noise. Once the location has ended, the indicator light on the 123 Robot will pulse white.
Monitoring Battery Life
The state of each 123 Robot’s Battery is listed. This can be used to monitor the Battery life of one or more 123 Robots within range.
Adjusting the Volume
The 123 Robot can play various sounds. To adjust the volume of a 123 Robot, select the 123 Robot that is to be adjusted from the VEX Devices list.
Drag the Volume selector from 7% to 100% to set the volume of the 123 Robot.
Select Save Settings.
Adjusting the Sleep Time
The 123 Robot will go to sleep (power itself off) after a set amount of time. To adjust the 123 Robot’s sleep time, select the 123 Robot that is to be adjusted from the VEX Devices list.
Drag the Sleep Time selector to 2, 5, or 10 minutes to set the sleep time of the 123 Robot.
To learn more about understanding the Device info for a connected 123 Robot, see this article.
Accessing Help in the VEX Classroom App
Select the Help icon at the top right of the VEX Classroom App.
Select the name of the Help document that you want to read to open it in the app.
Select the Help icon again to close the Help documentation.
