Modifying VEX GO Activities as well as other resources from the Teacher Portal using Microsoft Office can be accomplished in a few easy steps by using ‘Download.’
The following article will cover:
- How to ‘Download’ a VEX GO Google Doc to be opened in Microsoft Word
- How to ‘Download’ a VEX GO Google Sheet to be opened in Microsoft Excel
- Some example resources
Open the Educator Resource or Activity you would like to modify.
For this example, the Astronaut Vault VEX GO Activity will be used. To learn more about VEX GO Activities, view this article.
Open the activity and select ‘File.’
Select the expand icon beside ‘Download’ and select ‘Microsoft Word (.docx).’ This will download the file as a Microsoft Word document to your device’s download location.
You can launch Microsoft Word and open the file from your device’s download location. Note that the file now has a .docx extension for Microsoft Word.
You can now use Microsoft Word’s features on the document.
Note: when opening a Google Doc in Microsoft Word, there may be formatting changes depending on the document.
Open the Educator Resource you would like to modify.
For this example, the VEX GO Cumulative Pacing Guide will be used. To learn more about the Cumulative Pacing Guide, view this article.
Select the expand icon beside ‘Download’ and select ‘Microsoft Excel (.xlsx).’ This will download the file as a Microsoft Excel spreadsheet to your device’s download location.
You can launch Microsoft Excel and open the file from your device’s download location. Note that the file now has a .xlsx extension for Microsoft Excel.
Now you can use Microsoft Excel’s features on the spreadsheet.
You can use the procedures above to ‘Download' many different resources. Some examples include:
- Letter Home : another great example of a resource is found in every VEX GO STEM Lab. This letter can save countless hours by having all the pertinent information already created for parents and by using ‘Download,’ you can use Microsoft Word to customize it for each class!
- VEX GO Content Standards: a resource to show the alignment of standards to the VEX GO STEM Labs.
- There are many other resources found within the VEX GO STEM Labs Teacher Portal that can be easily modified using ‘Download.’ For more information about the educator resources provided to support VEX GO, view this article.
