Using Example Python Projects in VEXcode VR
Example projects are a great resource if you are just getting started with VEXcode VR. They allow you to observe how different Python commands in VEXcode VR are used.
Using Python Example Projects
Menu for opening example Python projects in VEXcode VR
To open an Example Project, select the File menu.
Example Python project open in VEXcode VR editor with the Playground and code workspace displayed
Choose ‘New Text Project’
Example Python project open in VEXcode VR with the Playground and Python editor visible
Choose ‘Open Examples.’
Example Python project open in VEXcode VR with the virtual robot and code editor visible
Icons for many different Example Projects will be shown. Each icon represents a different project and is colored according to the command categories.
VEXcode VR with a Python example project open in the editor and Playground
The Filter bar can be used to quickly find a specific type of example.
Example Python project open in the VEXcode VR workspace and Playground
To open any example, select one from the menu.
Python commands for the example project will populate in the Workspace. These commands and their parameters can be changed or removed. Additional Python commands can be added to modify the example project.
Starting an Example Project in the Playground
Example Python project open in VEXcode VR with the VR Playground displayed
Select the Playground icon in the Toolbar to launch the Playground.
Example Python project open in VEXcode VR with the Playground visible
Select ‘Start’ in the Toolbar.
Note: selecting ‘Start’ from the Toolbar will launch the Playground if it is not already opened.
Start menu showing Example Projects for opening Python examples in VEXcode VR
Or, select the ‘Start’ icon on the Playground window.
VEXcode VR Tutorials menu showing example Python projects available to open
Be sure to Save to your device if you want to Reload the project.
Descriptions in Python Example Projects
In each Python Example Project, the description provides a short summary for what the project does.
