Connecting with App-based VEXcode GO on Chromebook
Google has announced the discontinuation of support for Chrome Apps on Chromebooks starting in January 2025. As a result, Chrome Apps, including the VEXcode GO App, will no longer be visible in the Chrome Web Store or functional after that date. While the VEXcode GO App will remain available until this change takes effect, we encourage users to transition to the Web-based version of VEXcode GO well in advance. Go to Connecting with Web-based VEXcode GO on Chromebook to learn how to connect your GO Brain to VEXcode on web-based VEXcode GO.
It takes just a few steps to connect a GO Brain to app-based VEXcode GO on your Chromebook.
GO Battery with its connection cable plugged into the Battery Port on a GO Brain.
Connect the GO Brain to the Battery.
Diagram of a hand pressing down on the Brain's power button to turn it on. The button will glow green when it is turned on.
Turn on the GO Brain by pressing the button in the center.
VEXcode GO application icon.
Launch app-based VEXcode GO.
VEXcode GO with the Brain icon on the Toolbar highlighted.
Open VEXcode GO and select the Brain icon in the Toolbar.
VEXcode GO with the Brain dropdown menu opened and the Connect button highlighted.
Select Connect.
Dialogue box open to select the GO Brain to connect to. Three Brains with different names are shown, and the one named GO 2 is highlighted.
A list of available GO Brains will appear. Select the name of the Brain you want to pair.
Dialogue box open to select the GO Brain to connect to. One Brain has been selected and the Pair button below is highlighted.
Once a Brain is chosen, select the Pair button.
VEXcode GO with an orange Brain icon on the Toolbar to indicate that it is connecting.
The Brain icon will turn orange and a Connecting to: message will appear while the Brain is connecting.
VEXcode GO with a green Brain icon on the Toolbar to indicate that the Brain has connected.
Once the VEX GO Brain is connected the Brain icon will turn green. The message in the window will say Connected to: and list the name of the VEX GO Brain that is connected.
To Disconnect a VEX GO Brain from App-based VEXcode GO
VEXcode GO with a connected Brain and the Brain dropdown menu opened. The Disconnect button is highlighted.
Select ‘Disconnect’ to disconnect your GO Brain from VEXcode GO.
If You Are Experiencing Connection Issues
