It takes just a few steps to connect a GO Brain to app-based VEXcode GO on your Chromebook.
Connect the GO Brain to the Battery.
Turn on the GO Brain by pressing the button in the center.
Launch app-based VEXcode GO.
Open VEXcode GO and select the Brain icon in the Toolbar.
Select ‘Connect.’
A list of available GO Brains will appear. Select the name of the Brain you want to pair.
Once a Brain is chosen, select the ‘Pair’ button.
The Brain icon will turn orange and a ‘Connecting to:’ message will appear while the Brain is connecting.
Once the VEX GO Brain is connected the Brain icon will turn green. The message in the window will say ‘Connected to:’ and list the name of the VEX GO Brain that is connected.
To Disconnect a VEX GO Brain from App-based VEXcode GO
Select ‘Disconnect’ to disconnect your GO Brain from VEXcode GO.
If You Are Experiencing Connection Issues
- For troubleshooting support, view the Troubleshooting Connecting to App-based VEXcode GO VEX Library article.
- If you are still having trouble connecting your VEX GO Brain to VEXcode GO, see this VEX Library article to troubleshoot your Bluetooth connection on Chromebook.
- If you are unable to resolve your issue, please contact VEX support.
