Connecting a VEX GO Brain to a Chromebook
It takes just a few steps to connect a GO Brain to your Chromebook.
Connect the GO Brain to the Battery.
Turn on the GO Brain by pressing the button in the center of the Brain.
Launch VEXcode GO.
Open VEXcode GO and select the Brain icon in the Toolbar.
Select ‘Connect.’
A list of available GO Brains will appear. Select the name of the Brain you want to pair.
Once a Brain is chosen, select the ‘Pair’ button.
The Brain icon will turn orange and a ‘Connecting to:’ message will appear while the Brain is connecting.
Once the Brain is connected, the icon will turn green. The message in the window will say ‘Connected to:’ and list the name of the GO Brain that is connected to this Chromebook.
To disconnect from a Brain, select ‘Disconnect.’
If you are experiencing connection issues, select ‘Help Connecting VEX GO.’
