Download on iPad - Blocks Tutorials - VEXcode V5
Downloading and running a project with VEXcode V5 is as easy as four steps.
First, save the project and then choose which of the V5 Brain’s slots to download to.
First save
Next, connect the V5 Brain and check that its icon is green and other icons are white.
Nex connect
 Then, select ‘DOWNLOAD’ to download the project to the V5 Brain’s selected slot.
Then select
Note: The Download and Run icons will turn briefly gray until the download is complete.
Watch the progress bar to see when the project is done downloading.
Watch the progress
Note: The progress bar will disappear when the project is done downloading.
Finally, run the project on the V5 Brain.
Finally run
Select ‘RUN’ to run the project from the Toolbar.
You can also run
Note: Running the project from the Toolbar will cause the project to be downloaded again before running.
Or, disconnect the robot from the computer and run the project by selecting it on the V5 Brain.
Or disconnect
Note: The main menu screen only shows slots 1, 2, and 3. For projects that are downloaded to slots 4-8, first select the ‘Programs’ folder.
Note the main
