Using Python Example Projects and Templates in VEXcode V5
Example projects and Templates are a great resource if you are just getting started with VEXcode V5 and want to explore different robot behaviors. Example projects and Templates also allow you to observe how different commands in VEXcode V5 are used.
The following article will cover:
  • Using Python Example Projects
  • Using Templates
  • Descriptions in Python Example Projects and Templates
File open example
To open an Example Project, select the File menu and choose Open Examples.
List of examples
Icons for many different Example Projects will be shown. Each icon represents a different project and is colored according to the command categories.
Filter bar
The Filter bar can be used to quickly find a specific type of example.
Changing velocities
To open any example, select one from the menu.
Changing velocities
Commands for the example base project will populate in the workspace. These commands and their parameters can be changed or removed. Additional commands can be added to modify the example project.
Green download
Save and download the example to try it on your robot.
Using Templates
Template
There is also a special type of example called a Template.
Device
Templates have a special icon and are used to create a blank project with a preset device configuration.
Edited
If using a standard robot build, like the Clawbot, a Template can be used to quickly get started with a new project.
Description
Each Python Example Project and Template contains a description in the workspace. Descriptions can be used to document certain information in a project.
description
In a Python Example Project, the description provides a short summary for what the project does and also lists the device configuration.
configuration
In a Template, the description notes which devices are listed in the configuration.
