Convert a Blocks Project to Text - Blocks Tutorials
A blocks project can easily be converted to a text project in VEXcode V5.
This article will cover:
  • How to Convert a Blocks Project to Text
Once you have a blocks project created in VEXcode V5, the project can be converted into a text project.
Blocks project
Note: the blocks project shown in this article uses the Clawbot (Drivetrain, 2-motor, No Gyro) template.
Clawbot Drivetrain no motor
Open the Code Viewer by selecting the icon in the top right next to the Devices icon.
Code Viewer
The Code Viewer shows the text version of the blocks project in the workspace.
Code Viewer
There is the option to convert the blocks project to either C++ or Python. The option to select C++ is coming soon.
C or Python
Once you are ready to convert the blocks project to a text project, select the “Convert to Text Project” button in the bottom right of the Code Viewer.
Convert to text
If you have not yet saved your blocks project, a window will appear to prompt you to save your project as a .v5blocks file. For more information about saving a project, view the Knowledge Base articles on Saving a project (Windows, macOS, Chromebook).
Save window
Once the blocks project is saved, the text workspace will appear. You will be prompted to save your text project as a .v5python file. For more information about saving a project, view the Knowledge Base articles on Saving a project (Windows, macOS, Chromebook).
Save window python
Once the project is saved, you can continue working on your text project or download the project to a V5 Brain.
Converted to text
