Saving a V5 Python Project on Chromebook
When working in VEXcode V5, it is important to understand how to save a project on a Chromebook.
The article will cover:
  • How to Save a Python Project in VEXcode V5 (Chromebook)
  • Using ‘Save’
  • Using ‘Save As’
Using ‘Save’
Saving VEXcode V5 Python projects is easy. First, select the project name window.
Project
A Save dialog window will open.
VEXcode
Name your project by typing in your device's Save dialog window.
Drive
Notice the .v5python file extension after the file name. All VEXcode V5 Python files will have this file extension.
Select the destination, such as the Downloads folder.
Drive
Then select ‘Save.’
Save
The file will save to the chosen destination on your device. All VEXcode V5 Python projects are recognizable by their .v5python extension.
My file download
The updated project name will be visible in the project name window.
Drive forward
Once a project is saved, VEXcode V5 will automatically save all changes in a project.
Autosave
Note: Whenever there is an unsaved project VEXcode V5 will prompt users to save their work if the user attempts to:
  • Close VEXcode V5
  • Create a new project
  • Open another project
Using ‘Save As’
You can also use the ‘Save As’ option from the File menu to make a copy of a project under a different name or in a different location.
File
