A project can be loaded and saved in VEXcode VR in a few ways.
Load an Existing Project
Load an existing project by selecting “Load From Your Device” from the File menu.
Use the Windows interface to navigate and open your existing project. VEXcode VR will only allow you to open files with a .vrblocks file extension.
Open an Example Project
Open an example project by selecting “Open Examples” from the File menu.
Rename a Project
To rename a project, select the project name box.
Enter the project name, and select “Rename.”
Save Using the File Menu
Open the File menu and select “Save To Your Device.”
The file will be downloaded. Select and open “File Explorer.”
Inside "File Explorer," you can see your Downloads folder. Select the Downloads folder to open it.
In the Downloads folder, you'll see a file with a .vrblocks extension. This means your project has been successfully saved.
Common Issue when Loading/Saving
A common issue when using VEXcode Project files (.vrblocks) is trying to select the .vrblocks file to be opened directly by the operating system.
If you try to open a VEXcode Project file (.vrblocks) by double clicking it, it will show the following error message:
Or the following:
All VEXcode VR Project files (.vrblocks) can ONLY be opened within VEXcode VR. View the "Load an Existing Project" section from this article for more information.
