A project can be loaded and saved in VEXcode VR in a few ways.
Open an Existing Project
Open an existing project by selecting Open from the File menu.
Use the ChromeOS interface to navigate and open your existing project.
Important: Google Chrome supports autosave. Once you've opened or initially saved a project, VEXcode will automatically save all subsequent changes.
Open an Example Project
Open an example project by selecting Open Examples from the File menu.
To learn more about using Example Projects in VEXcode VR view this article.
Rename a Project
To rename a project, select the Project Name window.
Once the project name has been changed, the Save button will be enabled. Select Save to apply the new name to your project.
A prompt will open to save the file to your computer. Type in the text field at the bottom to change the name of your project.
Select Save to change the name of your project.
The autosave indicator to the right of the project's name will now change to Saved.
Now when you select the Project Name window, selecting Save As will let you save a new copy of the project with a different name.
Save Using the File Menu
Open the File menu and select Save or Save As.
If you have not yet saved your project, a prompt will open to save the file to your computer. Type in the text field at the bottom to change the name of your project.
Select Save to save your project.
Common Issue when Loading/Saving
A common issue when using VEXcode Project files is trying to select the project file to be opened directly by the operating system.
If you try to open a VEXcode Project file by double clicking it, nothing will open.
All VEXcode VR Project files can ONLY be opened within VEXcode VR. View the Open an Existing Project section from this article for more information.
