Loading and Saving a VEXcode VR Project on an Android
A project can be loaded and saved in VEXcode VR in a few ways.
Note: Due to browser limitations, different web browsers will display varying options for saving and loading. Be sure to follow the instructions specific to your browser. Don't see your browser listed? Make sure your browser supports VEXcode VR here.
Load an Existing Project
Google Chrome
File menu showing options to load a project from your device or save a project to your device
Open an existing project by selecting Load From Your Device from the File menu.
If you have not already given permissions to your web browser to access files on your device, you may be prompted to grant those permissions.
Select ALLOW to grant those permissions.
Android menu showing Load from your device and Save to your device options in VEXcode VR
Select Files.
Saved VEXcode VR project file in the Android Downloads folder
Use the Android interface to navigate and open your existing project. VEXcode VR will only allow you to open files with a .vrblocks file extension.
Microsoft Edge
Project menu with Save to your device selected
Use the Android interface to navigate to your existing project and select it to open. VEXcode VR will only allow you to open files with a .vrblocks file extension.
Firefox
Project menu showing options to load from or save to your device
Silk Browser
Save to your device option in the VEXcode VR project menu
Open an Example Project
Examples menu open in VEXcode VR on Android
Open an example project by selecting Open Examples from the File menu.
To learn more about using Example Projects in VEXcode VR view this article.
Rename a Project
Load and Save menu in VEXcode VR on Android showing options to open or save a project
To rename a project, select the Project Name window.
Save project dialog with Robot Drive filename and Save selected
Select the text field to change the name of the project. You will only be able to select Save once the project's name is changed.
Select Save to rename the project.
VEXcode VR menu showing Load from your device and Save to your device options on Android
Once saved, the name of project will be changed to its new name.
Important: Autosave is not supported on mobile devices. You must manually save your project to retain any name changes.
Save Using the File Menu
Google Chrome
VEXcode VR menu with Load from your device and Save to your device options on Android
Open the File menu and select Save To Your Device.
Prompt to save or discard changes before closing the VEXcode VR project
If you have not already given permissions to your internet browser to download files on your device, you may be prompted to grant those permissions. Select Continue.
Android notification confirming the VEXcode VR project file was saved to Downloads
The Download notification will appear and let you know your project has been saved in the Android device’s Downloads folder.
Select Open to go directly to your device's Downloads folder.
VEXcode VR menu showing the Save to your device option on Android
In the Downloads folder, you'll see a file with a .vrblocks extension. This means your project has been successfully saved.
Important: Autosave is not supported on mobile devices. You must manually save your project to retain any changes.
Microsoft Edge
Save VEXcode VR project to Android device
Android download prompt to save the VEXcode VR project file locally
When prompted to save the project, select Download.
Android prompt to confirm leaving the page before opening VEXcode VR
The Download notification will appear and let you know your project has been saved.
Select Details to see where your project has been saved.
Project menu option to save a VEXcode VR project to your Android device
You'll see a file with a .vrblocks extension. This means your project has been successfully saved.
Firefox
Save to your device option in the VEXcode VR menu on Android
Silk Browser
Menu button in VEXcode VR on Android
Selected VEXcode VR project file in the Android Files app
Common Issue when Loading/Saving
VEXcode VR menu showing options to load or save a project on an Android device
A common issue when using VEXcode Project files (.vrblocks) is trying to select the .vrblocks file to be opened directly by the operating system.
If you try to open a VEXcode Project file (.vrblocks) by tapping it, it will show this error message.
VEXcode VR menu showing options to load or save a project on your device
All VEXcode VR Project files (.vrblocks) can ONLY be opened within VEXcode VR. View the Load an Existing Project section from this article for more information.
