Loading and Saving a VEXcode VR Project on macOS
A project can be loaded and saved in VEXcode VR in a few ways.
Note: Due to browser limitations, different web browsers will display varying options for saving and loading. Be sure to follow the instructions specific to your browser. Don't see your browser listed? Make sure your browser supports VEXcode VR here.
Check for Autosave Compatibility
Browser compatibility for autosaving varies. To determine if your browser supports this feature, follow these steps:
Project name field displays “VEXcode Project” with status “Not Saved”.
Select the project's name.
Browser prompt asking to allow VEXcode VR to save files on this Mac
If the web browser can support autosave, it will say Autosave Capable Browser.
If autosave is available, VEXcode will automatically save all changes once you've opened or initially saved a project to your computer.
Save dialog indicating autosave is unavailable for the VEXcode VR project on macOS
If the web browser cannot support autosave, it will say Autosave Unavailable.
If autosave is not available, you must manually save your project after each change to prevent data loss.
View the "Save Using the File Menu" section of this article to learn how to save your project.
Open an Existing Project
Google Chrome or Microsoft Edge
File menu showing Open Project and Save options on macOS
Open an existing project by selecting Open from the File menu.
VEXcode Project.vrblocks file selected in Downloads for opening in VEXcode VR
Use the macOS interface to navigate and open your existing project. VEXcode VR will only allow you to open files with a .vrblocks file extension.
Firefox or Safari
File menu with options to save or load a VEXcode VR project on your device
Open an existing project by selecting Load From Your Device from the File menu.
Open an Example Project
Load and Save menu options for opening or saving a VEXcode VR project on macOS
Open an example project by selecting Open Examples from the File menu.
Learn more about using example projects in VEXcode VR view this article.
Rename a Project
To rename a project, select the Project Name window.
Save dialog with the project name field selected to rename the VEXcode VR project before saving.
The text inside the Project Name window will be highlighted. Type in the new name of your project.
Save dialog showing the project name Robot Drive ready to be saved
Once the project name has been changed, the Save button will be enabled.
Select Save to apply the new name to your project.
Save dialog with Robot Drive.vrblocks selected for saving the VEXcode VR project.
Select where you want to save your project and then select Save.
File menu showing Open Project and Save to your device options on macOS
The autosave indicator to the right of the project's name will now change to Saved.
Save As dialog for naming and saving a VEXcode VR project on macOS
Now when you select the Project Name window, the Save button will have changed to a Save As button.
Firefox
Project name field in VEXcode VR showing where to enter or view the project title
Save dialog showing the project name field must be completed before the Save button becomes available
macOS Save dialog showing the VEXcode VR project name field and save location options
Once the project name has been changed, the Save button will be enabled. Select Save to apply the new name to your project.
Project name field displays Robot Drive without a saved indicator
The project name will change at the top of the project.
Important: Firefox does not support autosave. Project name changes won't be saved until you manually save the project to your device.
Safari
Once the text inside the text field has changed, the Save button will be enabled. Select Save to apply the new name to your project.
Important: Safari does not support autosave. Project name changes won't be saved until you manually save the project to your device.
Save option in the VEXcode VR File menu on macOS
Open the File menu and select Save or Save As.
Save dialog showing the project named VEXcode Project.vrblocks being saved to Downloads
Saved VEXcode VR project file in the Downloads folder
Your file will be saved in the chosen location.
Firefox
File menu showing options to open examples, open a project from your device, save to your device, and save as in VEXcode VR
Open the File menu and select Save To Your Device.
Browser notification confirms the VEXcode project file downloaded successfully.
The save notification will appear at the top of the browser.
Your file will be saved to the default download location.
Important: Firefox does not support autosave. Any changes to the project won't be saved until you manually save the project to your device.
Safari
Download button in the VEXcode VR toolbar on macOS
The download notification will appear at the top of the browser.
Important: Safari does not support autosave. Any changes to the project won't be saved until you manually save the project to your device.
Common Issue when Loading/Saving
macOS message that Drive.vrblocks cannot be opened because no application is set to open the file
A common issue when using VEXcode project files is trying to select the project to be opened directly by the operating system.
To open these files correctly, any VEXcode VR files must be opened in VEXcode VR.
