Loading and Saving a VEXcode VR Project on macOS
A project can be loaded and saved in VEXcode VR in a few ways.
Load an Existing Project
Load From Device
Open an existing project by selecting “Load From Your Device” from the File menu.
Use the macOS interface to navigate and open your existing project. VEXcode VR will only allow you to open files with a .vrblocks file extension.
Open an Example Project
File Open Examples
Open an example project by selecting “Open Examples” from the File menu.
Rename a Project
Project name
To rename a project, select the project name box.
rename
Enter the project name, and select “Rename.”
Save Using the File Menu
Save to device
Open the File menu and select “Save To Your Device.”
Finder icon
The file will download. Select and open "Finder."
Downloads folder
In the Downloads folder, you'll see a file with a .vrblocks extension. This means your project has been successfully saved.
Common Issue when Loading/Saving
Open error
A common issue when using VEXcode Project files (.vrblocks) is trying to select the .vrblocks file to be opened directly by the operating system.
If you try to open a VEXcode Project file (.vrblocks) by double clicking it, it will show the following error message:
Load From Device
All VEXcode VR Project files (.vrblocks) can ONLY be opened within VEXcode VR. View the "Load an Existing Project" section from this article for more information.
