Troubleshooting Exit Code 2 on VEXcode Pro V5
Make process closed with exit code 2 is generally a compilation/build error.
How to troubleshoot the make error 2:
  • Whenever you see the make process closed with exit code 2 error you can read the log in the output to see where the error is within your program. The Output can provide information on the following:
    • What row/column the error is in within the file
    • What the cause of the error is
Information from the Output:
VEXcode Pro V5 code editor and Output panel showing error message ‘expected ; after expression’ with location src/main.cpp:20:30 highlighted and corresponding line in code marked.
In the following example, the output is providing the information that there is an error on line (row) 20 column 30. This is shown as, “20:30.”
What the cause of the error is...
VEXcode Pro V5 Output panel highlighting missing semicolon after Brain.Screen.print(“Hello”) with an arrow indicating the missing semicolon and its location.
The output also provides information as to why the error is shown. A semicolon is missing after the expression, “Brain.Screen.print(“Hello”)”
Note: If you are running an older version of the VEXcode Pro V5 application, previous versions of VEXcode Pro V5 were allowing special characters in the filename or the project name.
