The following article will walk you through how to install VEXcode IQ with MSI installers.
MSI installers are created to assist IT Administrators with site-wide deployments. If you are not an IT Administrator, you should install the .EXE version to avoid issues found here.
For additional help installing the .EXE version of VEXcode IQ, view this article.
Steps for Installation
- If you are using a remote deployment system such as SCCM you may need to install the Driver Signing Certificate before running the driver installer.
- First, install the VS 2013 Redistributable.
- Next, download and install the MSI version of VEXcode IQ found here.
- Finally, once the VS 2013 Redistributable and VEXcode IQ are installed, run the following as an administrator with elevated permissions:
C:\Program Files (x86)\VEX Robotics\IQDrivers\Console Driver Installer.exe
