Installing VEXcode IQ 3.x with MSI Installers
The following article will walk you through how to install VEXcode IQ version 3.x with MSI installers.
MSI installers are created to assist IT Administrators with site-wide deployments. If you are not an IT Administrator, you should install the .EXE version to avoid issues found here.
VEXcode IQ Download options for Desktop including Chrome Web Store, Windows, and Mac platforms. The Download for Windows option is highlighted.
For additional help installing the .EXE version of VEXcode IQ, view this article.
Steps for Installation
  1. If you are using a remote deployment system such as SCCM you may need to install the Driver Signing Certificates before running the driver installer.
    1. Download these three certificate files:
      1. Certificate 1
      2. Certificate 2
      3. Certificate 3
    2. Certs can be installed with the following commands using Microsoft’s certutil command.
      certutil -addstore "TrustedPublisher" VEXroboticsCert23.cer
      certutil -addstore -f -v root VEXroboticsCert23.cer
      certutil -addstore "TrustedPublisher" VEXRoboticsCert20.cer
      certutil -addstore -f -v root VEXRoboticsCert20.cer
      certutil -addstore "TrustedPublisher" RobomatterIncCert.cer
      certutil -addstore -f -v root RobomatterIncCert.cer
  2. First, install the VS 2013 Redistributable.
  3. Next, install the VS 2017 Redistributable.
  4. Then, download and install the MSI version of VEXcode IQ found here.
    Download options for Desktop including Chrome Web Store, Windows, and Mac platforms. One link below the Windows download button reads MSI (For IT). A link below that one reads MSI Help, and both of the MSI links are highlighted.
  5. Finally, once the VS 2013 Redistributable, the VS 2017 Redistributable, and VEXcode IQ are installed, run the following as an administrator with elevated permissions:
    C:\Program Files (x86)\VEX Robotics\IQDrivers\Console Driver Installer.exe
