Downloading a Blocks Project on iPad in VEXcode IQ
Downloading and running a project with VEXcode IQ is as easy as four steps.
VEXcode IQ Toolbar with the Slot icon highlighted in between the Tutorial and Project Name fields.
First, save the project and then choose which of the Brain’s slots to download to.
VEXcode IQ Toolbar with the Brain and Download icons highlighted together in a box. The Brain icon is colored green.
Next, connect the Brain and check that its icon is green and the Download and other icons are white.
VEXcode IQ Toolbar with the Download icon highlighted in between the Brain and Run icons.
Then, select Download to download the project to the Brain’s selected slot.
Note: The Download, Run, and Stop icons will turn briefly gray until the download is complete.
VEXcode IQ with the Downloading prompt and its progress bar shown.
Watch the progress bar to see when the project is done downloading.
Note: The progress bar will disappear when the project is done downloading.
VEXcode IQ 1st gen Brain screen is shown with the Programs menu opened and the VEXcodeProject program selected.
Finally, run the project on the Brain.
VEXcode IQ Toolbar with the Run icon highlighted in between the Download and Step icons.
You can also Run the project from the toolbar.
Note: Running the project from the toolbar will cause the project to be downloaded again before running.
