You can save your project in VEXcode IQ in different ways:
- Selecting Save in the File menu
- Downloading a new project
- Naming a new project
Choose one of the ways above to name a new project and then select "Create Document" on the next screen.
Note:you can change the save location of your project by selecting the back button at the top of the screen.
If your your iPad first goes to the main iCloud Drive folder, select the VEXcode IQ folder to Create Document and save your project inside of it.
Use the keypad to name your new project.
Select "OK" after naming the project.
After a project is saved, VEXcode IQ will automatically save all changes in a project.
Saving a Copy
You can also use the "Save As" option from the File menu to make a copy of a project under a different name or in a different location.
