Downloading a Blocks Project on iPad in VEXcode IQ
Downloading and running a project with VEXcode IQ is as easy as four steps.
First, save the project and then choose which of the Brain’s slots to download to.
Next, connect the Brain and check that its icon is green and the Download and other icons are white.
Then, select Download to download the project to the Brain’s selected slot.
Note: The Download, Run, and Stop icons will turn briefly gray until the download is complete.
Watch the progress bar to see when the project is done downloading.
Note: The progress bar will disappear when the project is done downloading.
Finally, run the project on the Brain.
You can also Run the project from the toolbar.
Note: Running the project from the toolbar will cause the project to be downloaded again before running.
