Use this link to open the VEXcode V5 Chrome Web Store page and select "Add to Chrome."
Select “Add app” to give VEXcode V5 access to your Chromebook
Note: You will likely see a small popup while the application is downloaded to your Chromebook.
Select “Launch app” to start VEXcode V5 after the download is complete.
Note: You can also find the application in your Application Library and open it from there next time.
Begin working in VEXcode V5.
Create a new project to get started with coding in VEXcode V5!
- Name and save your project (macOS, Windows, Chromebook).
- Configure your motors, drivetrain (with or without the Gyro Sensor), 3-Wire Devices, and controller.
- For help in understanding the blocks, access the Help feature.
