Installing VEXcode V5 on Chromebook
Due to Google's decision to discontinue support for Chrome Apps on Chromebooks starting January 2025, all Chrome Apps will no longer be visible in the Chrome Web store and will be unable to function.
While you can still add VEXcode V5 from the Chrome Web Store to your Chromebook until then, it will become unusable once Google discontinues Chrome Apps. We strongly recommend transitioning to the Web-based version of VEXcode V5, which offers all the capabilities and functionality of the App-based version. For more information on making this transition, please visit our guide on switching from App-based VEXcode V5 to Web-based VEXcode V5.
Install VEXcode V5
VEXcode V5 listing in the Chrome Web Store with the Add to Chrome button highlighted.
Use this link to open the VEXcode V5 Chrome Web Store page and select "Add to Chrome."
Chrome Web Store pop up after pressing the Add to Chrome button. The pop up reads Add VEXcode V5? and shows that the app needs USB device access, Bluetooth device access, and file and folder writing access with files that are opened with the app. Below the Add App button is highlighted.
Select “Add app” to give VEXcode V5 access to your Chromebook
Note: You will likely see a small popup while the application is downloaded to your Chromebook.
VEXcode V5 listing in the Chrome Web Store after the app has been installed. The Launch App button is highlighted.
Select Launch app to start VEXcode V5 after the download is complete.
Note: You can also find the application in your Application Library and open it from there next time.
VEXcode V5 application opened on a Chromebook.
Begin working in VEXcode V5.
Create a new project to get started with coding in VEXcode V5!
