Installing VEXcode V5 on Windows
First, download VEXcode V5 if you have not done so already.
VEXcode V5 Installer icon as shown after downloading it for Windows.
Select the VEXcode V5 Installer icon to begin installation.
VEXcode V5 Setup pop up window that reads Uninstalling old version of VEXcode V5. The OK button below is highlighted.
If there is a previous version of VEXcode V5 on the computer, the installer will first uninstall the old version of VEXcode. Select OK.
Note: You might have to grant permission for the app to make changes to your computer.
VEXcode V5 Setup window showing the End User License Agreement. The I Agree button below is highlighted.
The License Agreement will appear. After you have finished reading through the EULA, select I Agree.
VEXcode V5 Setup window showing the Installation Options, with a choice between installing the application for only the current user or all users. The Install button below is highlighted.
Choose the installation button for the installer, whether it will be installed only for the current user, or for all users on the computer. Once chosen, select Install.
VEXcode V5 Setup window showing the Completing VEXcode V5 Setup screen. The Finish button below is highlighted.
Wait for the installation to complete, then select Finish.
VEXcode V5 application icon installed on Windows.
Launch VEXcode V5 using the desktop shortcut.
VEXcode V5 application installed and opened on Windows.
Begin working in VEXcode V5.
Create a new project to get started with coding in VEXcode V5!
