Configuring a custom IQ Controller in VEXcode IQ (1st gen)
This article has been archived. See the updated article here.
You can use the VEX IQ Controller with your robot without programming using a customized VEXcode IQ project.
For this example, we will configure two individual motors and a Drivetrain that will be assigned to the Controller’s buttons and Joysticks. The two individual motors that we will use for this example will be the Arm and Claw motors from the Clawbot configuration. If you do not have a Clawbot, you can still add two individual motors following the same steps.
The ports for the individual motors and Drivetrain are as follows:
  • Motors:
    • ArmMotor: port 10
    • ClawMotor: port 11
  • Drivetrain:
    • LeftMotor: port 1
    • RightMotor: port 6
The steps that we will follow in this article are:
  • Adding Motors
  • Adding a Drivetrain
  • Adding a Controller
  • Assigning the Motors to the Controller’s Buttons
  • Assigning the Drivetrain to the Controller’s Joysticks
  • Saving Changes
  • Download and Run a Project
Adding Motors
VEXcode IQ Toolbar with the Devices icon highlighted in between the Code Viewer and the Help icons.
To configure a motor, select the Devices button to open the Devices window.
VEXcode IQ Devices menu with the IQ Robot Brain generation setting shown. This setting is set to the 1st gen option.
Select the generation that you are working with.
VEXcode IQ Devices menu with the Add a device button selected.
Select “Add a device.”
VEXcode IQ Devices menu after the Add a device button has been selected. The Motor option is highlighted.
Select “Motor.”
VEXcode IQ Select a Port menu where the specific port for the Smart Motor can be selected. Port number 10 is highlighted.
Select the desired port number for your motor. For this example, select port 10 for your Arm Motor.
VEXcode IQ Devices window with the Motor options shown. Above, the Motor's name is highlighted to indicate that it can be renamed. In this example, the name is set to ArmMotor.
Re-name the Arm motor by changing the name in the text box at the top of the Options screen to “ArmMotor”. If you select an invalid name, the text box will highlight red to indicate that the chosen name is not available.
VEXcode IQ Devices menu after selecting the Smart Port and renaming the Motor. Below, the Done button is highlighted.
Once the motor is re-named, select “Done” to submit the device to the configuration. Leave the direction selection as-is unless you would like to further customize the motor.
Note: Selecting “Cancel” will undo any changes you have made to the device and will not be a part of the configuration.
Note: For more detail about configuring a motor, click here.
Repeat “Adding a Motor” steps for adding the Claw Motor and select port 11. Do not add the Drivetrain motors using these steps.
Once the motors have been added, the next step is to add the Drivetrain. A Drivetrain can be used both with and without a Gyro. This is example will be focused on adding a Drivetrain without a Gyro.
  • To configure a Drivetrain with a Gyro click here.
Adding a Drivetrain
To configure a Drivetrain, select the Devices button to open the Devices window if it is not already opened.
VEXcode IQ Devices menu after the Add a device button has been selected. The Drivetrain 2 motor option is highlighted.
Select “Drivetrain 2-Motor.”
VEXcode IQ Devices menu after the Drivetrain 2 motor option has been selected to be added. A menu shows Port options for the Left Motor, and the Port number 1 has been selected.Next, a menu shows Port options for the Right Motor, and the Port number 6 has been selected.
Select the desired port numbers for your Left and Right motors. For this example, we will select port 1 for the Left Motor and port 6 for Right Motor. Ports that are already configured for other devices will be unavailable. Port 2 is shown grayed out as an example of a port that is unavailable.
After selecting Ports for the Left and Right Motors, the Port for the Gyro should be selected. In this example, there is no used Gyro so the Gyro checkbox has been unchecked and is highlighted.
Turn the Gyro off by un-checking the Gyro box.
VEXcode IQ Devices menu after selecting the Drivetrain Ports and with the Drivetrain Settings screen shown. Below, the Done button is highlighted.
Once the Drivetrain has been configured, select “Done” to submit the device to the configuration or “Cancel” to return back to the Devices menu. Leave the Drivetrain settings as-is unless you would like to further customize them.
Note: For more options about configuring a Drivetrain without a Gyro, click here.
The Controller can now be added to the configuration after the individual motors and Drivetrain have been configured.
Adding a Controller
To configure a Controller, select the Devices button to open the Devices window if it is not already opened.
VEXcode IQ Devices menu after the Add a device button has been selected. The Controller option is highlighted.
Select "Controller".
Now that the Controller has been added to the robot configuration, the Arm and Claw motors can now be assigned to the Controller’s buttons and the Drivetrain can be assigned to the Controller’s Joysticks.
VEXcode IQ Devices menu with the Controller options shown. There is a diagram of all of the buttons on the controller, and each button can be connected to Motor Groups or Drivetrains by selecting them in the diagram. The buttons aside from the joysticks are highlighted. The L axis buttons are connected to a Motor labeled ArmMotor, and the F axis buttons are connected to a Motor labeled ClawMotor.
Configure a motor to a button by clicking on the buttons on the Controller. Clicking the same button multiple times will cycle through your configured motors. Stop once the desired motor is displayed. The controller has four button groups (L, R, E, and F). Each group can have a single motor (that is not apart of the Drivetrain) configured to them. For example, ArmMotor cannot be configured for both the L and R button groups, only one of them. Once a motor has been configured, it will not display as an option for the other buttons.
VEXcode IQ Devices menu with the Controller options shown. The joysticks are highlighted but aren't set to any action yet.
You can change the drive-mode of the robot using the Joysticks by selecting the buttons to cycle through the modes until the desired mode is shown. The four modes are: Left Arcade, Right Arcade, Split Arcade, Tank.
VEXcode IQ Devices menu with the Controller options shown. The left joystick button has an icon that indicates that it is connected to Left Arcade on the Drivetrain.
Left Arcade - All movement is controlled by the left Joystick.
VEXcode IQ Devices menu with the Controller options shown. The right joystick button has an icon that indicates that it is connected to Right Arcade on the Drivetrain.
Right Arcade - All movement is controlled by the right Joystick.
VEXcode IQ Devices menu with the Controller options shown. The left and right joystick buttons have icons that indicate that they are connected to Split Arcade on the Drivetrain.
Split Arcade - Forward and backward movement is controlled by the left Joystick while turning is controlled by the right Joystick.
VEXcode IQ Devices menu with the Controller options shown. The left and right joystick buttons have icons that indicate that they are connected to Tank on the Drivetrain.
Tank - The left motor is controlled by the left Joystick while the right motor is controlled by the right Joystick.
Note: For more options about configuring a Controller, click here.
Once the Controller has been Configured, the changes need to be saved.
Saving Changes
VEXcode IQ Devices menu with the Controller options shown. The L axis buttons are connected to a Motor labeled ArmMotor, and the F axis buttons are connected to a Motor labeled ClawMotor. The left and right joystick buttons have icons that indicate that they are connected to Split Arcade on the Drivetrain. Below, the Done button is highlighted.
Select “Done” to complete the configuration or the changes will not be saved.
Now that the Controller has been configured and the changes have been saved, the project can now be downloaded and run.
VEXcode IQ Toolbar with the Download icon highlighted in between the Brain and Run icons.
Select Download to download the project to the Brain’s selected slot.
Note: The Download, Run, and Stop icons will turn briefly gray until the download is complete.
VEXcode IQ Toolbar with the Run icon highlighted in between the Download and Stop icons.
Select Run to start the project while your robot is still connected to your computer.
Note: For more information about how to download and run a project, click here.
