Download and Run a Project - Get Started - VEXcode IQ Blocks
Downloading and running a project with VEXcode IQ Blocks is as easy as four steps.
First, save the project (MacOS, Windows or ChromeOS) and choose which of the Brain’s slots to download to.
Next, connect the Brain and check that its icon is green and the Download and other icons are white.
Then, select Download to download the project to the Brain’s selected slot.
Note: The Download, Run, and Stop icons will turn briefly gray until the download is complete.
Finally, select Run to start the project while your robot is still connected to your computer.
Or, disconnect the robot from the computer and run the project on the Brain.
