Installing VEXcode V5 on macOS
To install VEXcode V5 on a Mac computer, first determine and download the appropriate installer for your system. Follow these steps to identify the correct installer and install VEXcode V5 on your macOS device.
Download the Installer
Diagram illustrating the installation process for V5 robotics components, showing labeled parts and connections to assist users in setting up their V5 system effectively.
On your Mac computer, select the Apple icon.
Diagram illustrating the installation process for V5 components, showing labeled parts and assembly steps.
Select About This Mac from the dropdown menu.
Diagram illustrating the installation process for V5 robotics components, featuring labeled parts and steps for assembly.
If your computer says it has an Intel processor, you will need to download the Intel installer.
Diagram illustrating the installation process for V5 robotics components, featuring labeled parts and connection points to guide users in setting up their V5 system effectively.
If your computer says it has an Apple chip, you will need to download the Apple Silicon installer.
Diagram illustrating the installation process for V5 components, including labeled parts and connections, to assist users in understanding the setup for V5 robotics systems.
Go to code.vex.com and scroll down to Get VEXcode and select VEXcode V5 >.
Diagram illustrating the installation process for the VEX IQ Robotics platform, showing key components and steps involved in setting up the system for educational and beginner robotics use.
If your computer uses an Intel processor, select Download for Mac (Intel).
If your computer uses an Apple chip, select Download for Mac (Apple Silicon).
Install VEXcode V5
Diagram illustrating the installation process for V5 robotics components, featuring labeled parts and assembly steps to guide users in setting up their V5 system effectively.
Once you have downloaded the correct installer for your Mac computer, double-click on the installer to begin the installation process.
Diagram illustrating the installation process for V5 components, including labeled parts and connection points, to assist users in properly setting up their V5 robotics system.
The End User License Agreement will appear. Once you have read through the EULA, select Agree.
Diagram illustrating the installation process for V5 components, featuring labeled parts and step-by-step instructions to assist users in setting up their V5 robotics system.
Once the installer has finished loading, the installation screen will open.
Diagram illustrating the installation process for V5 robotics components, showing step-by-step instructions and labeled parts.
Click and drag the VEXcode V5 application to the Applications folder.
Diagram illustrating the installation process for V5 robotics components, showing labeled parts and connections for proper setup.
If a dialog box asks you if you want to replace an existing VEXcode V5, select Replace.
Diagram illustrating the installation process for V5 robotics components, featuring labeled parts and step-by-step instructions to assist users in setting up their V5 system effectively.
Access your Applications folder and select VEXcode V5.
Diagram illustrating the installation process for V5 robotics components, featuring labeled parts and connections to guide users in setting up their V5 system effectively.
Begin working in VEXcode V5.
