VEX IQ Robotics Competition Virtual Driving Skills allows you to connect a VEX IQ (2nd gen) Controller to your computer and complete practice Driving Skills matches. This article walks through the options available to you when practicing Virtual Driving Skills.
Note: Virtual Driving Skills is available only when using a Chrome browser with a VEX IQ (2nd gen) Controller.
Playing a Virtual Driving Skills Practice Match
Virtual Driving Skills for VEX IQ can be accessed using this link.
Before beginning, ensure that your VEX IQ (2nd gen) Controller is connected to Virtual Driving Skills, and that you have your Virtual Skills Key ready.
- To learn how to connect your controller, see this article.
- To learn how to find your Virtual Skills Key and log into Virtual Driving Skills, see this article.
Once you have logged in using your Virtual Skills Key and connected your VEX IQ (2nd gen) Controller, the Virtual Driving Skills Practice Match is ready to play. The Controller Status will show green and display Connected in the upper left corner, and the Hero Bot will be in the starting position.
To start the match, press the Play button in the bottom-left corner.
A countdown will appear in the center of the screen, allowing you to prepare to start driving using your controller.
During the match, the time remaining is shown in the upper-right corner.
During the match, your score will update in the upper-left corner.
To end the match before time runs out, select the Stop button in the bottom-left corner.
At the end of the match, your team name and final score will be displayed. Select Retry to close this window and reset the field. Select the X in the upper left corner to close the window without resetting the field.
The Reset button in the bottom-left corner can also be used to reset the field layout.
Selecting a Drive Mode
Above the Virtual Driving Skills Practice Window, you will see options for selecting the Drive Mode.
The selected Drive Mode will show the name in dark blue and have a blue line around the icon.
To change the configuration, select the name of your desired Drive Mode.
Each Drive Mode sets the configuration of your controller joysticks and how the joysticks control the movement of the Drivetrain.
- Tank Drive — Drives the left motor of the robot using the left joystick, and the right motor of the robot using the right joystick.
- Left Arcade — Drives the robot forward, reverse, left, and right all using the left joystick.
- Right Arcade — Drives the robot forward, reverse, left, and right all using the right joystick.
- Split Arcade — Drives the robot forward and reverse using the left joystick, and turns the robot right and left using the right joystick.
Additional Settings
Camera Options
View options for the Field are located in the lower-right corner of the Virtual Driving Skills Practice Window.
- Driver Station Icon — Changes the camera to the view from the Driver Station.
- Top Down Icon — Changes the camera to be positioned above the Field.
- Chase Icon — Changes the camera to be positioned behind the robot.
Robot Configuration
The Drive Motors section enables you to set the Hero Bot's maximum velocity. Select the slider to change the velocity or type the desired maximum velocity in the text box.
The Intake Motor Group section enables you to set the maximum velocity for the Intake Motor, as well as set the controller buttons that control the Intake.
To adjust the velocity, select and drag the slider, or type the desired velocity limit in the text box.
To change the controller buttons, select the dropdown beside Intake and Outtake to set your desired buttons.
The Arm Motor section enables you to set the maximum velocity for the Arm Motor, as well as set the controller buttons that control the Arm.
To change the controller buttons, select the dropdown beside Arm Up and Arm Down to set your desired buttons.
Match Loads
You can add Match Loads to the Load Zone on the field using the Match Load buttons. Each match begins with four Match Loads of each color.
Select the color Bean Bag (red or blue) you wish to load. You can add one Match Load at a time. Once added, the counter will count down to show the remaining Match Loads available in that color.
Once selected, the Match Load will be added to the Load Zone corresponding to the color selected. You will not be able to add an additional Match Load until that one is picked up.
