To install VEXcode GO on a Mac computer, first determine and download the appropriate installer for your system. Follow these steps to identify the correct installer and install VEXcode GO on your macOS device.
Download the Installer
On your Mac computer, select the Apple icon.
Select About This Mac from the dropdown menu.
If your computer says it has an Intel processor, you will need to download the Intel installer.
If your computer says it has an Apple chip, you will need to download the Apple Silicon installer.
If your computer uses an Intel processor, select Download for Mac (Intel).
If your computer uses an Apple chip, select Download for Mac (Apple Silicon).
Install VEXcode GO
Once you have downloaded the correct installer for your Mac computer, double-click on the installer to begin the installation process.
The End User License Agreement will appear. Once you have read through the EULA, select Agree.
Once the installer has finished loading, the installation screen will open.
Click and drag the VEXcode GO application to the Applications folder.
If a dialog box asks you if you want to replace an existing VEXcode GO, select Replace.
Access your Applications folder and select VEXcode GO.
Begin working in VEXcode GO.
Go to Opening, Saving, and Renaming VEXcode GO Projects on macOS for more information on how to rename and save your VEXcode GO project.
