Opening and Saving VEXcode GO Projects on macOS
A project can be opened and saved in app-based VEXcode GO on macOS in a variety of ways.
Create a New Project
A new project opens when VEXcode GO is launched. But, a new project can also be opened from the File Menu.
VEXcode GO Toolbar with the File menu open and the New Blocks Project option highlighted. New Blocks Project is the first option in the menu.
Select New Blocks Project from the File Menu.
VEXcode GO unsaved project prompt that reads Your project was never saved. Save now?
Note: when creating a new project, a prompt will appear asking to save if the current project has not already been saved. See the "Saving Projects" section of this article for details on how to save a project.
Open Projects
Open an Existing Project
VEXcode GO Toolbar with the File menu open and the Open option highlighted. Open is the second option in the menu, below New Blocks Project. A hotkey of the command key with the letter O key can be used to open a project as well.
Open an existing project by selecting Open from the File menu.
Previously saved VEXcode GO project is visible from the device's files and is highlighted.
Use the device’s interface to navigate and open your existing project.
VEXcode GO with a previously saved Blocks project successfully opened.
Your project will then open.
Open an Example Project
VEXcode GO Toolbar with the File menu open and the Open Examples option highlighted. Open Examples is the third option in the menu, below New Blocks Project and Open.
Select Open Examples from the File Menu.
VEXcode Blocks Example Projects menu with a variety of projects across different categories to choose from.
Select an Example Project.
VEXcode GO with an Example Project opened, including a stack of code blocks and a note with a description of the project.
Once selected, the Example Project will open.
Saving Projects
You can save your project in VEXcode GO in different ways:
VEXcode GO Toolbar with the File menu open and the Save option highlighted. Save is the fourth option in the menu, below New Blocks Project, Open, and Open Examples. A hotkey of the command key with the letter S key can be used to save a project as well.
Option 1: Selecting Save in the File menu.
VEXcode GO Toolbar with the project name field highlighted. To the right of the Project Name a label reads Not Saved.
Option 2: Naming a new project by selecting the project name window.
VEXcode GO Project Name menu opened where the name can be changed. The Save button below is highlighted.
Type a new name into the text field and select Save.
Saving a Project
The device's Save As menu is open and set to save to the Documents folder.
Choose one of the ways above to save a new project, then a Save As dialog window will open.
The device's Save As menu is open and set to save to the Documents folder, with the project's name changed to Forest Quest and the Save button on the bottom right highlighted.
After choosing the location to save your project and typing in its name, select Save.
VEXcode GO Toolbar with the project name field highlighted and changed to Forest Quest.
The updated project name will be visible in the project name window.
VEXcode GO Toolbar with the project name field changed to Forest Quest. The label to the right is highlighted and reads Saved.
Once a project is saved, VEXcode GO will automatically save all changes in a project.
Note: Whenever there is an unsaved project, VEXcode GO will prompt users to save their work if the user attempts to:
  • Close VEXcode GO
  • Create a new project
  • Open another project
Using 'Save As'
VEXcode GO Toolbar with the File menu open and the Save As option highlighted. Save As is the fifth option in the menu, below New Blocks Project, Open, Open Examples, and Save.
You can also use the Save As option from the File menu to make a copy of a project under a different name or in a different location.
