Installing VEXcode 123 on iPad
VEXcode 123 requires iOS 15 or later to be installed on an iPad. Below, are the compatible iPad models for VEXcode 123:
  • iPad Air 2
  • iPad Air (2019)
  • iPad (2017)
  • iPad (2018)
  • iPad Mini 4
  • iPad Mini (5th generation)
  • iPad Pro (9.7-inch)
  • iPad Pro (10.5-inch)
  • iPad Pro (11-inch)
  • iPad Pro (12.9-inch 1st generation)
  • iPad Pro (12.9-inch 2nd generation)
  • iPad Pro (12.9-inch 3rd generation)
Note: Different prompts may appear depending on your iPad model and iOS version.
VEXcode 123 application opened on an iPad.
You can now code in VEXcode 123.
For instructions on managing VEXcode 123 projects on iPad, go to Opening and Saving VEXcode 123 Projects on iPad.
To connect your VEX 123 Robot to VEXcode 123, refer to Connecting with App-based VEXcode 123 on iPad.
