Running a V5 Learn Practice Compete STEM Lab Competition
Classroom competitions bring the excitement of VEX Robotics Competitions to your learning environment, enabling teachers to leverage the creativity and motivation of the competition setting in their classrooms. Organizing your classroom competition will help ensure its success, and make sure that you are your students are on the same page during class.
Organizing your students for competition
If the competition uses teams, assign teams to your students
The teacher should assign teams to the students, to identify which groups will work together in the competition. Post the teams in your classroom in a clearly visible space, so that students can quickly and easily see who they are working with.
Create a match schedule
Matches can move more smoothly if you and your students know when they are expected to be ready to compete. Most matches are 1 minute long, but you will need to allow time for setup and clean up, so that students can navigate the classroom space easily. So setting up a schedule that allows for roughly 5 minutes per match, should account for student movement, setup and cleanup.
Post the schedule with the teams, or print it and give it out to students so that they can clearly see when they are expected to be ready. This timetable will then set the parameters for students’ practice time. An example match schedule is shown below.
Example competition match schedule. The schedule is set up as a data table, with 3 rounds each with 3 matches, and 3 columns. The columns read Match Time, Team 1, and Team 2. The first round will have three matches running at 1:45, 2:00, and 2:05. Match one will be Team A vs Team B, match two will be Team C vs Team D, and match three will be Team E vs Team F. The other two rounds will have matches between the times of 2:10 to 2:35 and will have new matchups of the 6 teams.
You will want to have multiple rounds of the competition so that students can iterate on their strategy and build between matches, so establishing a time table will help you plan your class time to allow for a successful competition lesson. Having a predetermined schedule will also enable you to announce the matches throughout class, so that your focus can remain on scoring and timing at the competition Field.
Create a leaderboard
Post or project the match schedule on the whiteboard in your classroom, and give space for students to write in point totals and to identify the winner of each match. This visible record of matches can provide motivation for students as they continue to iterate, as well as give them an idea of other teams to scout as they develop game strategies.
You can also use the VEX V5 Leaderboard in your classroom. For more information about the V5 Leaderboard and how to use it, view this article.
Blank VEX V5 Leaderboard with features to help faciliate a classroom competition, including a scoreboard, a timer, and controls.
Setting up your space for competition
There are three main areas that you should designate within your space for your classroom competition:
  • A Competition Field - Have one central competition Field, or taped off area, where all matches will take place. This should be easily accessible to all students, and have enough space for students who are not in the match to observe, so that they can scout other teams. This will be the teacher’s main responsibility as your matches are taking place, as you will be responsible for scoring and keeping time, so putting in a centrally located space where you can still supervise your students is optimal.
  • A Practice Area - Have an additional Field, or taped off space, that students can use to practice for their competition matches. If space allows, you may want to have more than one practice area, so that multiple teams can practice simultaneously.
  • Team Meeting and Preparation Spaces - Have several tables or meeting spaces available for alliances to use as their ‘home base’, or ‘pit’, throughout the competition. This will give space for documenting in their engineering notebook, meeting to develop game strategy, or building and iterating on their robots.
An example layout of a classroom space could include a centrally located competition Field, with desks pushed along one side of the classroom as Team Meeting spaces, and a practice space designated on the other side of the room. You will need to determine what works best for your setting, based on your space constraints and the needs of your students.
Diagram of a classroom layout that is prepared for a V5 STEM Lab Classroom Competition. One side of the room has a bulletin board on the wall with the alliance and match schedules, and the teacher's desk is nearby. The opposite wall has a white board to display the leaderboard. In the middle of the room there are rectangles marking a practice space, the Competition Field, and 8 desks to serve as alliance meeting spaces.
In this example, the flow within the space would be something like this:
  • The teacher would be based between the Competition Field and the Leaderboard.
  • At the end of a match, the teacher announces the winner, and writes the scores on the Leaderboard, while the two groups that competed clear and reset the Competition Field for the next match.
  • The teacher announces the next groups to compete, giving them a “2 minute warning” to the start of their match.
  • Once the Field is cleared, the students who finished competing return their robot to the Meeting Space to strategize for the next round, and the students coming up to play can gather at the Competition Field from the Practice Space and/or Meeting Space.
To learn more about facilitation strategies during classroom competitions, see this article.
