Using the VEX V5 Leaderboard
The VEX V5 Leaderboard is a fun and interactive tool that can be used to display and document student performance in the STEM Labs, keeping students engaged with each other.
Blank VEX V5 Leaderboard with features to help faciliate a classroom competition, including a scoreboard, a timer, and controls.
Using the VEX V5 Leaderboard with Your Classroom
The VEX V5 STEM Lab are focused around Rethink challenges. Challenges promote collaboration and naturally motivate students to improve their robots, their strategy, and their code. The VEX V5 Leaderboard is designed to help facilitate these challenges by providing an interactive tool for educators to use to present and record challenge data.
Display the leaderboard throughout your challenge to show team scores and ranking, making it easy for students to visualize overall team performance throughout the challenge.
You can also run your challenge with VEX Classroom Games, which includes a live leaderboard, a match timer, and awards with printable certificates. To learn more, see Getting Started with VEX Classroom Games.
Example VEX V5 Leaderboard after a competition was completed, with 3 teams and their final scores listed.
Customizing the Leaderboard for Your Challenge
The steps below outline how to add information and customize the leaderboard for your classroom challenge.
Access the VEX V5 Leaderboard
Screenshot of the VEX Leaderboards page, with a list of Leaderboard pages for each VEX platform. The V5 Leaderboard option is highlighted.
To access the VEX V5 Leaderboard, go to https://education.vex.com/leaderboard/. Then select the V5 Leaderboard.
Name Your Leaderboard
Side by side screenshots of the VEX V5 Leaderboard, with an arrow indicating that the leaderboard name has been changed to User Interface Challenge.
The leaderboard name text is editable.
Rename the leaderboard by selecting “Leaderboard Name” and edit the text.
Select anywhere outside of the name text or select "Enter" once finished.
Label Score Columns
Side by side screenshots of the VEX V5 Leaderboard, with an arrow indicating that the score column's name has been changed to Number of Objects.
The score column text is editable.
Rename the columns by selecting the title and edit the text.
Select anywhere outside of the text or select "Enter" once finished.
VEX V5 Leaderboard with the plus and minus icons highlighted. These icons can be used to add and remove score columns.
Select the "+” or “-” icon to add or delete score columns.
Add Team Names
VEX V5 Leaderboard with a team's name selected and highlighted, showing that it can be customized.
Select a team in the Team Name column to enter a team name in the leaderboard.
VEX V5 Leaderboard with the Add Team button highlighted in the bottom left corner.
Add more teams by selecting the “Add Team” button.
VEX V5 Leaderboard with the trashcan icon highlighted that can be used to remove a specific team.
Delete teams by selecting the trashcan icon.
VEX V5 Leaderboard that has three named teams added, ready to start.
Once you have added all participating teams and score columns, you are ready to start the classroom challenge.
Running a Classroom Challenge with the VEX V5 Leaderboard
The leaderboard makes it easy to run a classroom challenge. The accessible interface allows you to display the time for all students competing to see, as well as input scores and see team rankings update in real time as the challenge progresses.
Keep Time for Challenges
VEX V5 Leaderboard with the Start button highlighted to the right of the timer.
Select “Start” to start the timer on the leaderboard.
VEX V5 Leaderboard with the Stop button highlighted to the right of the timer.
Select “Stop” to end the challenge run and stop the timer.
VEX V5 Leaderboard with the Reset button highlighted to the right of the timer.
Select “Reset” to set the timer back to zero for the next run of the challenge.
See Scores and Team Ranking in Real-time
VEX V5 Leaderboard with a specific score selected and highlighted, showing that the scores can be edited.
Add team scores by selecting a score in the score column, then add the score. Scores can be changed or overwritten at any time.
VEX V5 Leaderboard with a row of custom scores highlighted, indicating that each score is added together automatically to create the Total Score.
Scores for multiple runs are automatically totaled for each team and appear in the "Total Score" column.
VEX V5 Leaderboard with the team rankings highlighted, indicating that the teams are automatically ordered and ranked by the highest total score.
As scores are added, the teams will automatically be ordered by rank from highest to lowest score. If two teams have the same score, they will share the same rank.
Document and Celebrate Student Performance
VEX V5 Leaderboard with the Print Leaderboard button highlighted at the bottom of the page.
Select “Print Leaderboard” to print or save the the entire leaderboard as a PDF.
Example VEX V5 Leaderboard PDF after the Print Leaderboard button has been selected. The Leaderboard's name and all the Team names and scores are shown.
The PDF will display the team names as well as the scores.
VEX V5 Leaderboard with a team's printer icon highlighted. The printer icon can be used to generate and print an individual Team's certificate.
Select the printer icon to print or save an individual team certificate as a PDF.
Example VEX V5 Leaderboard team certificate. It reads Rank 2, User Interface Challenge, Team Red, Total score 3.
The certificate will include the challenge name, team name, team rank, and the team's total score.
