The IQ Smart Motor transforms your Robot Battery's energy into dynamic movement, powering your robot's diverse functionalities like wheels, arms, claws, and other manipulators. This article will walk you through common problems when building with the IQ Smart Motor and solutions on how to address them.
The IQ Smart Motor
Your IQ Smart Motor, a distinguishable gray rectangular item, has three main features:
- Mounting holes for secure attachment to your build.
- A square output socket beside the mounting holes for efficient power transfer.
- A Smart Cable port for Robot Brain control.
For a deep dive into IQ Smart Motor Specifications, view this article from the VEX Library.
Problems and Solutions when Building with the IQ Smart Motor
Problem: The Motor Feels Unstable
Solution: Utilize the motor's 11 top holes. More pins provide a firmer setup because there are more points of connection. The Smart Motor should be viewed as a key construction component requiring a solid connection. This solution is demonstrated in this 3D instruction.
Like a standard construction piece, the motor has mounting holes compatible with any pins and standoffs from your kit, ensuring a robust connection. View this 3D instruction to see a Smart Motor connected to a Beam using pins and a Motor Shaft piece.
To connect the Smart Motor to your build, first press the pins into the mounting holes. Then, press the beam of your robot on top of the pins to secure the beam to the motor.
Removing the pins by hand might be challenging once inserted. For more information on removing tricky pins, view this article from the VEX Library that walks you through using the Pin Tool.
Mounting the IQ Smart Motor
Caps
Motor Support Caps allow two motors to sit together as a platform using mounting holes and connector pins. The Motor Support Cap prevents the motors from shifting during movement and maintains the stability of the build, as shown in this 3D instruction.
Mount
The Mount consists of four 2x10 beams supporting two motors connected together by a Dual Motor Support Cap. The Shafts attached to the motor provide support for attaching the wheels to the Mount, and the beams on the top and the bottom of the Mount allow the structure to easily attach to the larger robot build using pins. This Mount design is shown in the following 3D instruction.
Motor Drivetrain
The Motor Drivetrain refers to the system responsible for moving the robot. The Drivetrain contains the motor connected to the larger robot build, including the main body of the robot with the wheels. The Drivetrain translates the power from the motors into motion, allowing the robot to move forward, backward, and turn. View a robot with a Motor Drivetrain in this 3D instruction.
Problem: The Motors are Difficult to Mount
Solution: Things to keep in mind for the best way to mount motors:
- Ensure the Smart Cable port is accessible.
- Avoid interference between the motor and other mechanisms.
- Position the square output socket to deliver power as intended.
If you're a novice, start by assembling the IQ Education Kit Builds from builds.vex.com. Acquainting yourself with effective building practices will benefit future projects.
This image shows the IQ Clawbot, effectively utilizing Smart Motors for its drivetrain, arm, and claw mechanisms.
Problem: The Motor isn't Moving the Mechanism
Solution: The motor's unique square socket allows for straightforward shaft connections. To employ the full power of it, you first need to attach a driving shaft. Insert any shaft till it's flush with the motor's surface, ensuring continuous power delivery. If your motor is attached but not moving, double check the shaft is fully inserted, sometimes it may slip out over time and robot use. As depicted in the 3D instruction below, any shaft can be integrated into the motor's socket during the mounting process.
Thanks to their square shape, any shaft can fit into the motor's output socket, directing power to the required mechanism. Just push the shaft fully into the motor until it sits flush, enabling smooth power transmission.
For more information on selecting, capturing, and supporting VEX IQ shafts, view this article from the VEX Library.
Need further assistance? Explore the Mechanical section of the VEX IQ Library for insights on mechanisms, assemblies, and drivetrains. For hands-on learning, kick off with the IQ builds at builds.vex.com for motor mounting examples.
