To print to the Console in web-based VEXcode V5, a connection to the Console Serial Port is needed. This second port is needed because the first serial port links the V5 Brain to the device for project downloads from a browser.
Note: To print to the Console, the V5 Brain must stay connected to the device via a USB cable while using the Console Serial Port.
If the Console Serial Port is not connected, the Print Console in VEXcode V5 will show as unavailable.
Connecting to the Console Serial Port
Ensure the V5 Battery is charged and is connected to the V5 Brain.
Turn on the Brain by pressing the Power button on the Brain.
Connect the V5 Brain to your device using the Micro-USB cable.
Ensure the V5 Brain is connected to the device via the first web-serial port. For more information on this connection process, view the article for your device:
- Connecting with Web-based VEXcode V5 - Chromebook
- Connecting with Web-based VEXcode V5 - Mac
- Connecting with Web-based VEXcode V5 - Windows
The Brain icon should be green and the Brain name/Team number should appear.
Once the Brain is connected to the first web-serial port, select the green Brain icon again.
Select Connect Console Serial Port.
macOS/Chromebook
Windows
Select each image above to enlarge.
A prompt will appear based on your device. Select Continue.
macOS/Chromebook
Windows
- macOS/Chromebook: Select the V5 Brain with the HIGHEST ID number from the list of Brains available. The lowest ID number will already be paired.
- Windows: Select User Port. The Communications Port will already be paired.
macOS/Chromebook
Windows
Select Connect once your choice is highlighted.
Once the connection is successful, the Console Serial Port will display as Connected. The Print Console will now be available for use.
Disconnecting from the Console Serial Port
To disconnect your device from a V5 Brain, unplug the Micro-USB cable from your device or the V5 Brain.
You can also disconnect a V5 Brain from web-based VEXcode V5 by turning the Brain off.
Turn the Brain off by holding the Power button until the screen on the Brain goes black.
Both of the methods above will disconnect the V5 Brain from both web-serial ports, showing the V5 Brain icon as white.
