Accessing VEX V5 Virtual Skills with a Virtual Skills Key
Each VEX V5 Robotics Competition registered team is provided a Virtual Skills Key for accessing Virtual Skills in VEXcode VR. This article explains how to access both Virtual Coding Skills, and Virtual Driving Skills.
Finding Your Team's Virtual Skills Key
To find your team’s Virtual Skills Key, go to VEX Robotics Events.
VEX Robotics logo with three options underneath. The rightmost option reads login and is highlighted.
1. Select Login in the upper right corner.
The login window with fields for entering email and passwords.
2. Enter the email address and password associated with your account. Then select the Login button.
Don't have an account? Go here to create a VEX Robotics Events account.
The lefthand navigation on VEX Events with the My Teams option highlighted.
3. Once you have logged into your account, select My Teams from the account navigation.
The my teams tab in Vex events. A row is shown for each team. A highlight can be seen on the team number at the top of the row and on the virtual skills key on the bottom of the row.
4. Here you will see a list of your registered teams with their Virtual Skills Keys.
No key listed? Make sure that your team’s registration has been renewed for the current season.
Note: The Virtual Skills Key is specific for each team. If you have multiple teams, make sure to record which Key goes with each team.
Accessing Virtual Coding Skills
To practice coding with Virtual Coding Skills, you must first enter your team's Virtual Skills Key at vr.vex.com using a Chrome browser.
Note: The Virtual Skills Key can be used by multiple members of the same team.
VEXcode VR home page with a welcome screen and text that reads 'Have a VR Class Code? Login Here' highlighted at the bottom of the page.
When VEXcode VR is launched, you may see this window. Select Login Here to launch the login window.
VEXcode VR File menu with the last option 'Login with Code' highlighted.
If you do not see the window above, select File, then Login Code in order to launch the login window.
Login window with the team number field highlighted.
Enter your team number into the login window.
Login window with the 'Enter Skills Key' field highlighted.
Once the team number is entered, a space will appear to enter the Virtual Skills Key.
Note: The Virtual Skills Key is not case-sensitive.
Login Window with the Submit button at the bottom of the window highlighted.
After entering both a Team Number and Virtual Skills Key, select Submit to complete the login process.
Upper left corner of the VEXcode VR Toolbar with a red VR Logo highlighted.
Once logged in, the icon in the top left corner will turn white and red.
Accessing Virtual Driving Skills
Driving Skills Practice window with a Login window shown.
Launch VEX V5 Robotics Competition Driving Skills Practice by navigating to VEX V5 Driving Skills Practice on a Chrome browser.
Driving Skills practice login window with the Team number and Virtual Skills Key fields called out.
Enter your team number and your team's Virtual Skills Key.
The same Login window now with the Login button below the Virtual Skills Key field highlighted.
Once your Team Number and Virtual Skills Key are entered, select Login.
