示例:一个简单的最大公分母(GCD)函数(使用欧几里得算法)
以下示例还举例说明了如何在简单的循环结构中使用它。
不使用用户定义的函数:
int main() { int remainder = 1; int a1, b1, a2, b2; vexcodeInit(); a1 = a2 = 20; b1 = b2 = 64; while(remainder > 0){ remainder = a1 % b1; a1 = b1; b1 = remainder; } Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d", a2, b2, a1); a1 = a2 = 60; b1 = b2 = 200; while(remainder > 0){ remainder = a1 % b1; a1 = b1; b1 = remainder; } Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d", a2, b2, a1); }
使用用户定义的函数:
int getGCD(int a, int b){ int remainder = 1; while(remainder>0){ remainder = a % b; a = b; b = remainder; } return a; } int main() { vexcodeInit(); Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d",getGCD(20, 64)); Brain.Screen.printAt(5, 60, "GCD ( %d, %d ) = %d",getGCD(60, 100)); }
这里显示了来自调用函数 main() 的逻辑流序列:
示例:平均一组数值
loat doAverage(int n1, int n2, int n3){ float avg = (n1 + n2 + n3)/3; return avg; } int main() { int n1, n2, n3; Brain.Screen.print("average(%d, %d, %d) = %d", 10, 20, 30); doAverage(10, 20, 30); n1=10; n2=20; n3=40; Brain.Screen.print("average(%d, %d, %d) = %d", n1, n2, n3); doAverage(n1, n2, n3); }
示例:使一台机器人以可变编码器值前进
void reportMotionValues(){ Brain.Screen.printAt(5,100, "%8.2lf%8.2lf%8.2f", LeftMotor.position(rev), LeftMotor.position(deg)); } void goStraight(float totalEnc, float vel){ LeftMotor.resetPosition(); LeftMotor.setVelocity(50.0, percent);
LeftMotor.spinToPosition(totalEnc, deg, true); return; } int main() { int enc=1000; // >0: forward, <0: backward vexcodeInit(); for(int i=0; i<10; i++){ enc *= -1; goStraight(enc, 100); Brain.Screen.printAt(5,60, "Done"); reportMotionValues(); //this delay is here only for you to view these actions. //你不需要在这里设置一个延时。 wait(2000, msec); } }
如你所见,让机器人以可变次数前进和后退几乎是不可能的;因为它只能在运行时确定。
