Troubleshooting Unexpected Behavior in VEXcode VR on Microsoft Edge
In VEXcode VR, you may have encountered a problem with the VR Robot or Playground does not respond as expected. To solve this issue in a Microsoft Edge browser, you need to turn Hardware Acceleration on.
Enabling hardware acceleration allows the browser to utilize a computer's graphics processing unit (GPU) to do graphics intensive tasks. Because VEXcode VR Playgrounds are 3D applications, the hardware acceleration helps to improve the performance of the Playground.
Some common issues could occur if the hardware acceleration is turned off including the following:
  • Lower Frame Rate. This means the robot or Playground could seem to jerk or jump around because the frames cannot keep up with the speed of the moving robot or background of the Playground.
  • Some Playgrounds may show a black background when opened. This happens when the browser cannot render the graphics.
  • Projects may not work as expected because the sensor data being sent from the Playground to the VEXcode VR project is delayed.
  • The Pen of the VR Robot may have unexpected behaviors.
Microsoft Edge site permissions for app.vex.com with Insecure content set to Allow
Turning On Hardware Acceleration
Microsoft Edge Settings menu with Cookies and site permissions selected
Select the three dots on the top right of the screen.
Microsoft Edge setting blocking third-party cookies, which can cause VEXcode VR to behave unexpectedly
Select 'Settings' from the bottom of this dropdown menu.
Microsoft Edge setting to allow third-party cookies for VEXcode VR
In the Settings menu, select 'System and performance.'
Microsoft Edge Cookies and site permissions settings used to allow VEXcode VR site data
The hardware acceleration option will appear here. Select the toggle to the right to turn on hardware acceleration.
Edge settings page with Cookies and site data options used to troubleshoot VEXcode VR
After turning on hardware acceleration, you will be prompted to relaunch Edge.
Microsoft Edge Settings menu showing Clear browsing data option for VEXcode VR troubleshooting
After relaunching, you will see that the hardware acceleration toggle is set to on.
