Installing the VEX Drivers Installer for VEX EXP
To use VEX with a Windows computer, you must have the latest VEX Drivers installed. These drivers are essential because they allow your computer to recognize VEX devices and communicate with them properly. Without them, your computer won't know what the devices are or how to interact with them.
Note: These drivers are compatible with all VEX platforms (V5, EXP, etc.). If you've already installed these drivers for another VEX platform, you don't need to reinstall them.
Follow these steps to download and install the VEX Drivers:
Downloaded VEX Drivers Installer 2.0.0 is visible from the device's files and is highlighted.
First, download the VEX Drivers Installer.
Then, select the VEX Drivers Installer icon to launch the VEX Drivers Setup.
Windows alert that reads Windows protected your PC. Below, the More Info button is highlighted.
If your computer halts the installation, select More info.
Windows alert that reads Windows protected your PC. After selecting More Info, a Run Anyway button will appear. This button is highlighted.
Select Run anyway to resume installation.
When prompted about allowing the application to make changes to your device, select Yes.
VEX Drivers Setup window that reads Welcome to VEX Drivers Setup. The Install button below is highlighted.
In the first VEX Drivers Setup prompt, select the Install button.
VEX Drivers Setup window after installation that now reads Completing VEX Drivers Setup. The Finish button below is highlighted.
Wait for the installation to complete, then select Finish.
You have now installed the most current VEX Drivers for VEX EXP.
