Using VEX EXP Activities in the Classroom
Anatomy of an EXP Activity
Diagram of the Drive Forward and Reverse one-page Activity with each section of the activity labeled in detail to explain its purpose. A label points to the name and hook of the activity and reads 'Simple name with a brief hook for students to know what the activity is about'. Next, a label points to the Step by Step instructions and a label reads 'Step by Step instructions with supporting images for students to follow'. Next, a label points to the Level Up section and reads 'The Level Up section offers scaffolding extension ideas'. Next, a label points to the Pro Tips section and reads 'Pro Tips highlight VEX EXP building, coding, or curriculum related tips and tricks'. Finally, at the bottom a label points to the Standard section and reads 'Each activity is aligned to a standard'.
Your VEX EXP classroom is a multifaceted learning environment, enabling students and teachers to have hands-on, minds-on learning experiences through multiple avenues. VEX EXP STEM Labs offer teachers complete Units designed for whole-class instruction, while VEX EXP Activities extend that learning by giving students the opportunity to make their EXP builds, code and kits their own. EXP Activities are designed to be used both in conjunction with STEM Labs, and as stand-alone activities themselves.
Explore the VEX EXP Kit
Screenshot of the VEX EXP Scavenger Hunt Activity, shown as an example.
VEX EXP Activities allow for students to explore VEX EXP Kits and materials as individuals or in small groups. Some Activities encourage students to learn the names of pieces and where they are in the Kit. Other Activities allow students to explore how EXP pieces can be assembled into various shapes or to solve challenges.
Example Activities
Explore More Engineering Concepts
Screenshot of the VEX EXP The Claw Activity, shown as an example.
Engineering concepts are also covered in VEX EXP Activities. These Activities allow students to further explore building robots with the EXP Brain, building simple machines, or other ways to explore creativity in building.
Example Activities
Explore More Coding Concepts
Screenshot of the VEX EXP Color Sensing Activity, shown as an example.
There are VEX EXP Activities that allow students to further explore coding concepts with both Blocks and Python. Exploring the coding Activities allows for students to practice coding from STEM Labs or understand new coding concepts.
Example Activities
Conveniently located Above STEM Labs
VEX EXP Activities link at the top of the STEM Labs page is shown and highlighted.
All of the VEX EXP Activities can be found at the top of the VEX EXP STEM Labs page. Each activity is a one page Google Doc, that can be downloaded and printed, or accessed on any classroom device. Activities are continually updated and added to, so check back for new EXP Activities throughout the school year.
VEX EXP Activities can also be used in conjunction with STEM Labs. For more information about what Activities to use in sequence with the STEM Lab(s) you are teaching, check out the Cumulative Pacing Guide and 1:1 Pacing Guide.
