Using the VEX V5 Workcell Leaderboard
The VEX V5 Workcell Leaderboard is a fun and interactive tool that can be used to display and document student performance in challenges and competitions, keeping students engaged with each other and the competition.
Blank V5 Workcell Leaderboard with features to help faciliate a classroom competition, including a scoreboard, a timer, and controls.
Using the VEX V5 Workcell Leaderboard with Your Classroom Competition
VEX V5 Workcell STEM Lab Units 12 and 13 are focused around classroom competitions. Competitions promote collaboration and naturally motivate students to improve their designs, their strategy, and their code. This leaderboard is designed to help facilitate these classroom competitions by providing an interactive tool for educators to use to present and record competition data.
Display the leaderboard throughout your competition to show team scores and ranking, making it easy for students to visualize overall team performance throughout the competition.
Example V5 Workcell Leaderboard after a competition was completed, with 4 teams and their final scores listed.
Customizing the Leaderboard for Your Competition
The steps below outline how to add information and customize the leaderboard for your classroom competition.
Access the VEX V5 Workcell Leaderboard
Screenshot of the VEX Leaderboards page, with a list of Leaderboard pages for each VEX platform. The V5 Workcell Leaderboard option is highlighted.
To access the VEX V5 Workcell Leaderboard, go to https://education.vex.com/leaderboard/.
Name Your Leaderboard
Side by side screenshots of the V5 Workcell Leaderboard, with an arrow indicating that the leaderboard name has been changed to Capstone Project Competition.
The leaderboard name text is editable.
Rename the leaderboard by selecting “Leaderboard Name” and edit the text.
Select anywhere outside of the name text or select "Enter" once finished.
Label Score Columns
Side by side screenshots of the V5 Workcell Leaderboard, with an arrow indicating that the score columns' names have been changed to Trial 1 and Trial 2.
The score column text is editable.
Rename the columns by selecting the title and edit the text.
Select anywhere outside of the text or select "Enter" once finished.
For example, you may want to include multiple runs of the Capstone Project Competition in Lab 13 and have the teams with the highest combined score win. The leaderboard in this image has a column to track the score for each run.
V5 Workcell Leaderboard with the plus and minus icons highlighted. These icons can be used to add and remove score columns.
Select the "+” or “-” icon to add or delete score columns.
Add Team Names
V5 Workcell Leaderboard with a team's name selected and highlighted, showing that it can be customized.
Select a team in the Team Name column to enter a team name in the leaderboard.
V5 Workcell Leaderboard with the Add Team button highlighted in the bottom left corner.
Add more teams by selecting the “Add Team” button.
V5 Workcell Leaderboard with the trashcan icon highlighted that can be used to remove a specific team.
Delete teams by selecting the trashcan icon.
V5 Workcell Leaderboard that has four named teams added, ready to start.
Once you have added all participating teams and score columns, you are ready to start the classroom competition.
Running a Classroom Competition with the VEX V5 Workcell Leaderboard
The leaderboard makes it easy to run a classroom competition. The accessible interface allows you to display the time for all students competing to see, as well as input scores and see team rankings update in real time as the competition progresses.
Keep Time for Competitions
V5 Workcell Leaderboard with the Start button highlighted to the right of the timer.
Select “Start” to start the timer on the leaderboard.
V5 Workcell Leaderboard with the Stop button highlighted to the right of the timer.
Select “Stop” to end the competition run and stop the timer.
V5 Workcell Leaderboard with the Reset button highlighted to the right of the timer.
Select “Reset” to set the timer back to zero for the next run of the competition.
See Scores and Team Ranking in Real-time
V5 Workcell Leaderboard with a specific score selected and highlighted, showing that the scores can be edited.
Add team scores by selecting a score in the score column, then add the score. Scores can be changed or overwritten at any time.
V5 Workcell Leaderboard with a row of custom scores highlighted, indicating that each score is added together automatically to create the Total Score.
Scores for multiple runs are automatically totaled for each team and appear in the "Total Score" column.
V5 Workcell Leaderboard with the team rankings highlighted, indicating that the teams are automatically ordered and ranked by the highest total score.
As scores are added, the teams will automatically be ordered by rank from highest to lowest score. If two teams have the same score, they will share the same rank.
Document and Celebrate Student Performance
V5 Workcell Leaderboard with the Print Leaderboard button highlighted at the bottom of the page.
Select “Print Leaderboard” to print or save the the entire leaderboard as a PDF.
V5 Workcell Leaderboard PDF after the Print Leaderboard button has been selected. The Leaderboard's name and all the Team names and scores are shown.
The PDF will display the team names as well as the scores.
V5 Workcell Leaderboard with a team's printer icon highlighted. The printer icon can be used to generate and print an individual Team's certificate.
Select the printer icon to print or save an individual team certificate as a PDF.
V5 Workcell Leaderboard team certificate. It reads Rank 1, Capstone Project Competition, Green Team, Total Score 65.
The certificate will include the competition name, team name, team rank, and the team's total score.
Putting it All Together - Lauren's Story
Lauren is a high school robotics and engineering teacher and is preparing to run the Capstone Project Competition for Lab 13 of the Workcell STEM Labs. Her students have been iterating on their Workcell builds and code and they are excited to compete. Lauren set up the VEX V5 Workcell Leaderboard on her smartboard so that it can be displayed throughout the competition, and her students can easily see it to keep track of scores and team ranking.
VEX V5 Workcell build showing robotic arm, conveyors, disk feeder, and V5 Brain.
At the beginning of each run of the competition, Lauren can start and stop the timer directly from the leaderboard, so students can see both the time of each run, and their current score as they are competing. This ensures all students are on the same page and can remain focused on competing.
As the competition progresses, the excitement builds because each team can see their name move up and down in the ranking as more scores are added. When the competition is complete, Lauren prints out a certificate for each team that they can put in their engineering notebooks. This allows students to see how they progress from competition to competition.
Lauren also prints out the full competition leaderboard and displays it on the classroom bulletin board for all of her classes. She has a section for each class that displays a printout of the entire leaderboard for that class's competition. Students can see how their group's performance compares to teams in other classes, building a healthy competition that motivates her students to refine and improve their code, game strategy, and robot builds for each competition.
The VEX V5 Workcell Leaderboard helps Lauren motivate her students while giving them a way to contribute to running the classroom competitions. The leaderboard also provides a way for her and her students to collect and display the data from competitions in an authentic way.
