Creating a Maze in the Wall Maze+ Playground
The Wall Maze+ Playground in VEXcode VR expands upon the Wall Maze Playground and provides additional features to allow you to create your own maze.
Wall Maze+ Playground with the robot positioned at the maze entrance and the coding workspace ready to build a solution
Creating Your Own Maze
VEXcode VR workspace showing Wall Maze+ blocks alongside the maze playground for programming the virtual robot
To begin editing the maze, first select the menu button.
VEXcode VR Wall Maze Playground with block workspace and controls for testing maze navigation code
Then select the edit button.
Playground Features button in the Wall Maze+ Playground in VEXcode VR
In the editor window, you will see:
  • The number of start and end positions being used
  • If the maze is ready for use
  • An option to upload a maze
  • An option for saving the maze
  • The Clear icon
To change an element of the maze, select any square. Watch the video here to see how to select the square and how the square will change. The square will go through the following four options:
  • Brown: wall
  • Green: Start Position
  • Red: End Position
  • White: open area where the robot can move
To edit multiple blocks of the maze at once, select the square you would like to copy and drag your cursor as shown in the video here.
Note: The drag to copy action can only be used on the brown walls and the white open areas. It does not work for copying start or end positions.
Start and End Positions
VEXcode VR with the Wall Maze+ Playground and block code for navigating the robot through a maze
Start Positions are indicated by a green square with a letter. They will appear in alphabetical order as they are selected: "A," "B," "C," "D," and "E."
VEXcode VR Wall Maze+ Playground showing blocks to build and test a maze-solving project
End Positions are indicated by a red square. The color of these squares can be detected by the Down Eye Sensor on the VR Wall Maze+ Robot.
VEXcode VR Wall Maze+ Playground with the block workspace and robot controls displayed
You can have up to five Start Positions and five End Positions for the maze. This information can be found in the top left corner of the Playground Window.
VEXcode VR workspace showing the Wall Maze+ Playground and blocks used to create a maze program
VEXcode VR Wall Maze+ Playground with code blocks, maze view, and start controls
Wall Maze Playground selected in the Features menu
If you do not have a Start Position or End Position, the message will change to indicate what is missing.
VEXcode VR Wall Maze+ Playground showing the block coding workspace and robot position in the maze
Because the Maze is not ready for use, the Check and Save icons will be unavailable. These will turn a lighter shade and you will be unable to select them.
If the maze already has five ending or starting positions, that option will not appear as you select the square. In this video, the maze already has five end positions, so the red square does not appear.
Clear Icon
Wall Maze options in the Playground Features menu
If you do not want to start editing the maze from the default layout, select the Clear icon.
Wall Maze+ Playground showing coding blocks and controls used to program the virtual robot through a maze
This will remove all walls except those along the border. The Start Position and End Position will remain the same. From here you can begin to edit the walls of the maze as shown in the video above.
Note: The border walls remain as shown so that the VR MazeBot does not drive out of the Maze+ area.
Check Icon
VEXcode VR Wall Maze+ Playground workspace showing Blocks used to navigate the maze
After you have finished editing the maze, select the Check icon.
VEXcode VR with the Wall Maze+ Playground and block workspace for coding the virtual robot
You will be taken back to the main window of the Wall Maze+ Playground. A window will appear for you to select the Start Position of the VR MazeBot.
VEXcode VR with the Wall Maze+ Playground open and block commands ready to program the VR Robot
You can then change the Start Position of your robot at any time by selecting the menu button and then selecting the Location Icon.
Showing and Hiding the Mini-Map
VEXcode VR with the Wall Maze+ Playground and blocks to navigate the robot through a maze
A mini-map showing the top down view of the Wall Maze+ Playground is available by default in the top right corner of the Playground Window.
VEXcode VR workspace with Wall Maze+ Playground and blocks to navigate the robot through the maze
To hide the mini-map, select the map icon in the bottom right corner of the Playground Window.
VEXcode VR workspace with the Wall Maze+ Playground and maze view for programming the VR Robot
Select the map icon again to have the map reappear.
