Using Match Loads in V5RC Tipping Point
While completing a Tipping Point match in VEXcode VR, you may utilize Match Load Rings in accordance with the guidelines set out in the V5RC Tipping Point Game Manual and Appendix B - Skills Challenge.
Match Load Ring Locations
VEXcode VR workspace for the VRC Tipping Point Playground with block-based controls for programming the virtual robot
Select the eye icon to see where each of the Match Load Ring drop off locations are.
Field diagram showing the match load zone and scoring areas in V5RC Tipping Point
Location labels L1-4 will appear on the Field beneath any game elements. Each of these labels corresponds to one tile on the Field where a Match Load Ring may be placed.
To remove these labels, select the eye icon again.
Note: The starting position of Moby, the Hero Bot, determines where your Match Loads will appear during the game.
VEXcode VR playground for the Tipping Point challenge with block and text coding options for controlling the virtual robot
If Moby begins in position A or B, it is in the red Alliance Home Zone and all Match loads will be on the tiles along the West wall of the Field.
This is also indicated by the Match Load buttons appearing in red.
Field setup showing the legal match load zone and scoring location in V5RC Tipping Point
If Moby begins in position C or D, it is in the blue Alliance Home Zone and all Match loads will be on the tiles along the East wall of the Field.
This is also indicated by the Match Load buttons appearing in blue.
How to Place Match Load Rings
Match load zone and loading sequence in the V5RC Tipping Point field
You can see the current number of Match Load Rings available at any point during the match in the upper left of the Playground Window.
V5RC Tipping Point field showing the match load zone where game objects are introduced during play
Select the button that matches the tile where you want to place a Match Load Ring.
Note: You must start the project before any Match Load Rings can be placed on the Field.
VEXcode VR workspace with a Tipping Point project and virtual robot for demonstrating match loads
A Match Load Ring cannot be placed on a tile that contains a robot or game element. The Match Load buttons corresponding to that location will be greyed out to show they are unavailable.
