Identifying Location Details Using the GPS Sensor in Tipping Point
You can use the Game Positioning System™ (GPS) Sensor to help you navigate the Field in VEXcode VR's Tipping Point Playground, with the (X, Y) coordinates of locations.
How the GPS Sensor Works in VEXcode VR
VEXcode VR Tipping Point playground showing the block coding workspace and robot position on the field
The GPS Sensor uses the VEX Field Code on the interior of the V5RC Field to triangulate X, Y position and heading. That checkerboard pattern in the Field Code is used to identify the location for each individual block in that pattern. The VEX GPS is an absolute position system, so it does not drift nor does it require calibration on a per-field basis.
To sense the Field Code, the VEX GPS Sensor, a black and white camera, is mounted on the rear of the robot and faces rearwards.
The GPS Sensor reports the (X, Y) coordinates of the center of rotation of Moby on the Field, in millimeters or inches.
Identifying (X, Y) Coordinates on the V5RC Field
The Field in VEXcode VR ranges from approximately -1800mm to 1800mm for the X and Y positions. The starting location of Moby depends on the starting position selected.
The center location, or the origin (0,0), is located at the Neutral Mobile Goal in the center of the Field.
VRC Tipping Point field map with labeled zones, goals, platforms, and starting tiles for GPS location reference
Identifying the (X, Y) Coordinates of the GPS Sensor
VEXcode VR Tipping Point playground showing block and text coding interfaces for the virtual robot
The GPS Sensor can be used to identify the X and Y coordinates of Moby on the Field. These coordinates reflect the location of Moby’s center of rotation, which is located between the Forks, as indicated in this image.
VEXcode VR Tipping Point workspace with GPS sensor blocks for reporting the robot's location details
Reporter blocks from the Sensing category in the Toolbox can be used to report positional values from the GPS Sensor in your project.
VRC Tipping Point field layout with labeled home zones, platforms, goals, and robot starting positions
The current X and Y coordinates of Moby’s GPS Sensor on the Field can be displayed in the Print Console using blocks from the Looks category in the Toolbox.
Using the GPS Sensor to Help Moby Navigate the Field
You can use the GPS Sensor to help Moby navigate the Field by driving to specific locations using your knowledge of the Cartesian coordinate system. Using the GPS Sensor, Moby can drive along the X or Y-axes until the value of the sensor is greater than or less than a threshold value. This allows Moby to drive using sensor feedback instead of set distances.
GPS Sensor selected in the Devices menu of the VEXcode VR Tipping Point playground
In this project, Moby will drive forward from starting position D, until the value of the X-axis is less than 600mm, then stop, placing Moby’s center of rotation on the white tape line.
Note: You may have to account for the robot’s inertia or drift when setting your parameters.
GPS Sensor Location and the Center of Rotation on Moby
The GPS Sensor is mounted in the rear of the robot, whereas Moby’s center of rotation is located in the front of the robot.
The GPS Sensor is configured in V5RC Tipping Point to account for this offset (approximately 260mm), so that the values that are reported reflect the center of rotation of Moby.
The Radius of the Mobile Goals
Monitor console displaying the robot’s X and Y coordinates and heading in the Tipping Point playground
The Mobile Goals have a maximal diameter of 330.2mm (13 inches), so the distance from the center point to the edge of the Mobile Goal (the radius) is approximately 165mm (6.5 inches).
(X, Y) Coordinates of Game Elements in Tipping Point
Knowing the coordinates of game elements, like Mobile Goals, can help you plan your projects in VEXcode VR.
The following reference is provided as a guide, based on the Field setup at the start of each Match, for the approximate center point coordinate locations of the game elements on the V5RC Field. Remember to account for the radius of the Mobile Goal when using these coordinates to build your projects.
Mobile Goal Coordinates
GPS Sensor dashboard displaying the robot’s X and Y coordinates and heading in the Tipping Point playground
Ring Cluster Coordinates
VRC Tipping Point field diagram labeling zones, platforms, and goals for GPS sensor location reference
Platform Edge Coordinates
VEXcode VR project using the GPS Sensor to display the robot’s X and Y coordinates in Tipping Point
Identifying the GPS Heading of Moby
VEXcode VR Tipping Point workspace showing GPS Sensor blocks used to identify the robot’s X, Y, and heading values
The GPS Sensor can also be used to identify the GPS heading. The heading ranges from 0 degrees to 359.9 degrees, following a compass heading style.
When using the GPS Sensor to detect location, the GPS heading will remain constant in relation to the Field, regardless of the starting position of the robot.
