Welcome to the VEX Robotics Competition (VRC) Virtual Skills! To play the 2022 - 2023 VRC game, Spin Up, in Virtual Skills, you must be a member of a registered team. Once you are registered, you will use your Virtual Skills Key to log in to VRC Virtual Skills in VEXcode V5.
If you are a registered team with a Virtual Skills Key, follow the steps in this article to access VRC Virtual Skills and get started coding.
If you are not a registered team and do not have a Virtual Skills Key, your teacher or team mentor will need to first register your team with Robot Events. Once your team is registered, you can use your Virtual Skills Key and follow the steps in this article to access VRC Virtual Skills to get started coding.
Now you’re ready to code in VRC Virtual Skills!
Articles to Help You Get Started
To get started, learn about the ways to score points in this year's game manual. Then for added challenges, learn more about Disco, this year's Hero Bot, and other details about the Field so you can strategize and get a high score.
Looking for more?
Want to learn more advanced coding to help you beat your high score? VEXcode is used with all VEX Robotics platforms. Check out the Computer Science Level 1 - Blocks course and learn more about coding with VEXcode!
