Overview of V5 Chains and Sprockets
Sprockets
A chain and sprocket system refers to the interface between chains and sprockets for the purpose of driving, lifting, or enforcing power on another shaft.
Assorted V5 Sprocket pieces, with 5 sizes shown.
V5 Sprocket pieces are shown being linked together with chain pieces.
Chains and sprockets may look similar at first glance, but the difference between a chain and sprocket system and a gear system is that:
  • Gears cannot interface with chains, gears can only interface with other gears directly.
  • Sprockets are not designed to interface directly with other sprockets, rather they can interface indirectly between other sprockets through the use of a chain.
This 3D Build is an example of how sprockets can be used on a mechanism.
For this particular design, both motors share the same chain and sprocket system. This ties the force of the motors together, allowing for more power.
This can be used to lift heavy or multiple objects, or increase torque on a drivetrain design.
Watch this video to learn more about building with chains and sprockets.
The following is a table that explains the difference between low, medium, and high strength sprockets. Each column will explain what that particular sprocket is designed for, how many teeth are available for that classification of sprocket (different size options), and an example of a robot build or mechanism that uses that particular sprocket.
Sprockets
Standard Sprockets
Standard Sprocket piece shown from the front and the side. These Sprocket pieces are smaller.
6P Sprockets
6P Sprocket piece shown from the front and the side. These Sprocket pieces are a bit larger.
High Strength Sprockets
High Strength Sprocket piece shown from the front and the side. These Sprocket pieces are the largest.
Designed to carry moderate loads. Allowing for the construction of smaller, more compact mechanisms. Allowing for higher loads.
Five different sizes: 10T/15T/24T/40T/48T
Diagram comparing the different Standard Sprocket sizes. Outlines of each size of sprocket are shown concentrically to demonstrate the differences in size and tooth count.
Five different sizes: 8T/16T/24T/32T/40T
Diagram comparing the different 6P Sprocket sizes. Outlines of each size of sprocket are shown concentrically to demonstrate the differences in size and tooth count.
Five different sizes: 6T/12T/18T/24T/30T
Diagram of the V5 Legacy Clawbot build that utilizes Standard Sprocket pieces.
V5 Clawbot (Legacy) utilizing low sprockets.
Diagram of the EXP Cascading Lift build that utilizes 6P Sprocket pieces.
EXP Cascading lift utilizing medium chain and sprockets.
Diagram of the V5 Cascading Lift build that utilizes High Strength Sprocket pieces.
V5 Cascading Lift utilizing high strength chain and sprockets.
Chains
VEX chains come in three different sizes. When and how you use different sized chains are dependent on the outcome of a certain build or mechanism, and any additional constraints.
For example, do you need to build a mechanism that will require higher strength? Perhaps you want to construct a lift design that needs to lift multiple objects at once, and these multiple objects together could be heavy. In this case, the largest chain could be used. However, the largest chain will not be as compact of a design.
On the other hand, does your design need to be compact? Then the smallest chain can be used. However, the design may not be as strong, or able to lift multiple, or heavy objects. There are many elements to consider when designing using chains and additional links.
Chain & Additional Links
Image of Chain Diagram of the Chain link piece that is included with the Standard Sprocket and Chain kit. Diagram of the Chain link piece that should be used with the 6P Sprockets kit. Diagram of the Chain link piece that is included with the High Strength Sprocket and Chain kit.
Product Number 276-2166  228-4983  276-2172
Additional Links Product Number - -
276-7141
276-7578
Pitch Size in millimeters (mm) and inches (in, ")
Diagram that demonstrates that the Pitch Size of Chain link pieces are measured by the length of a Chain piece from one connection pin to the next.
3.75mm / 0.148" 6.35mm / 0.250" 9.79mm / 0.385"
